[工艺选型] HTRI计算换热器遇到的两条信息,不知道能否忽略
3.6K |1
mystarxkVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP北京市
如下,翻译了下是温度夹点相关,冷热物流有温度交叉工况,之前项目一般都是考虑双壳程串联换热器的设计,这个本身流量较小,选用了单管程单壳程的纯逆流设计,面对如下这两条意见,不知道要不要理会啊。
Local In-tube temperature pinch detected: Due to thermal stratification effects, a temperature pinch over a portion of the
tubewall may have occurred. HTRI methods do not currently account for this condition and the local mean temperature
difference (and hence incremental duty) may be over-predicted. Thermal stratification effects can be reduced by either
shortening the tube length to the point where the pinch begins or modifying process and/or exchange geometry to
increase the tubeside velocity. (MN 4128)
Intube temperature pinch predicted in tubepass  1: The localized temperature pinch could effectively nullify up to 41.3%
of the tubeside heat transfer surface area in this tube pass. (MN 4126)
发表于 2023-4-12 08:19:29
【提示:直接搜索3597251可直达本帖。】
当前内容由会员用户名 mystarxk 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
发表于 2023-4-12 08:19:45
【实名】高级模式
海川化工论坛网(hcbbs) @Discuz! X3  加载0.058603 second(s), 41 queries Redis On.
