HTRI 常见错误解释
8.6K |0
gzh256VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP江苏省
已绑手机   ★悬赏任务→ 发悬赏(3)  承接(0/0)
  • 任务信息
  • 需求描述
  • 任务规则
  • 余额充值
一共2条:
1,The program has failed to converge on a valid solution for the MTD. A temperature pinch may be present in the exchanger. Check the specified or calculated process conditions, physical properties, and heat release curves, and rerun the case after correction.
2,Extrapolation of the physical properties for the cold fluid with respect to pressure resulted in a negative value.  Theprogram reset the calculated negative physical property to 0.00001.  Check the physical properties shown in the Final Results Printout, and rerun the case if necessary.
一般是什么造成的?
发表于 2022-5-9 23:23:12
【提示:直接搜索3336640可直达本帖。】
当前内容由会员用户名 gzh256 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
【实名】高级模式
海川化工论坛网(hcbbs) @Discuz! X3  加载0.067688 second(s), 43 queries Redis On.
