[讨论] 一个完美的可燃液体罐区防火堤排水应该是什么样子的?
1.5K |2
罐区地面水排放有初期雨水、雨水、清净下水或受污染的消防水,外排方向有污水池、雨水管道、事故应急池等,一个标准的排放系统是个什么样子呢?
发表于 2021-3-25 09:30:11
渝琴 + 10 发起议题
当前内容由会员用户名 18848540 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
潜在客户VIP会员 VIP会员 | 显示全部楼层       最后访问IP安徽省
看什么罐区,一般我们是设一个排水沟,排水沟出水做切换,初期雨水和地面冲洗水进污水系统,清净雨水进雨水系统,事故水根据情况而定,可以走雨水系统,末端做一个切换,一路进事故水池,一路去雨水监控池,如果是原油需要切水,会在储罐旁边做一个收水口
发表于 2022-7-21 17:05:45
API2510
排水部分:“5.2 Drainage 5.2.1 The ground under and surrounding an LPG tank or pressure vessel used to store LPG shall be graded to drain any liquid spills to a safe area away from the vessel and piping. The grading shall be at a slope of at least1 %. 5.2.2 The drainage system shall be designed to prevent spilled liquid from one LPG tank or pressure vessel from flowing under any other LPG tank or pressure vessel. In addition, the drainage system design shall minimize the risk to piping from spilled LPG. 5.2.3 The spill drainage area shall not contain equipment, except as permitted by this standard. 5.2.4 Walls, dikes, trenches, or channels are permitted to assist in draining the area.”
发表于 2022-8-3 16:02:06
海川化工论坛网(hcbbs) @Discuz! X3  加载0.088719 second(s), 45 queries , Redis On. 劰载中...
