【Chemical Process Equipment: Selection and Design, Third Edition】
4.2K |16
vivasun851228VIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
(请先登录或注册成为海川会员后查看)-h ... 登录查看全文
发表于 2009-10-24 19:18:49
【提示:直接搜索561005可直达本帖。】
当前内容由会员用户名 vivasun851228 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
xw335400VIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
发表于 2010-3-8 15:11:03
zhanggy608VIP会员 VIP会员 | 显示全部楼层       最后访问IP吉林省
(请先登录或注册成为海川会员后查看)-a ... 登录查看全文
发表于 2010-3-9 08:04:06
skyouchenVIP会员 VIP会员 | 显示全部楼层       最后访问IP江苏省
发表于 2010-7-12 17:28:02
drongonVIP会员 VIP会员 | 显示全部楼层       最后访问IP新加坡国际航空电讯集团公司(SITA)
发表于 2010-7-14 18:53:35
yuxinyang_01VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
发表于 2010-10-9 13:18:22
ChangE17VIP会员 VIP会员 | 显示全部楼层       最后访问IP云南省
发表于 2010-10-12 23:28:45
airkaiVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
(请先登录或注册成为海川会员后查看)-T ... 登录查看全文
发表于 2010-10-24 14:19:31
eremiteqsyVIP会员 VIP会员 | 显示全部楼层       最后访问IP天津市
发表于 2011-1-3 12:27:12
发表于 2011-1-3 12:29:27
发表于 2011-1-3 12:32:41
发表于 2011-1-3 12:53:00
asugVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
发表于 2011-6-12 08:42:36
vivasun851228楼主 VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP上海市
Chemical Process Equipment: Selection and Design Third Edition
James R. Couper, W. Roy Penney, James R. Fair, Stanley M. Walas,
Gulf Professional Publishing
2009
ISBN: 0123725062
A facility is only as efficient and profitable as the equipment that is in it. This highly influential book is a powerful resource for chemical, process, or plant engineers who need to select, design or configure plant successfully and profitably.
Written by some of the most experienced and well-known chemical and process engineers in the industry today, this information-packed volume gives the chemical or process engineer or engineering student all of the guidelines for the design and selection of chemical process equipment. Comprehensive and practical, its scope and emphasis on real-world process design and performance of equipment will prove invaluable for day-to-day problem solving.
The comprehensive and influential guide to the selection and design of a wide range of chemical process equipment, used by engineers globally . Copious examples of successful applications, with supporting schematics and data to illustrate the functioning and performance of equipment
Revised edition, new material includes updated equipment cost data, liquid-solid and solid systems, and the latest information on membrane separation technology
Provides equipment rating forms and manufacturers' data, worked examples, valuable shortcut methods, rules of thumb, and equipment rating forms to demonstrate and support the design process
Heavily illustrated with many line drawings and schematics to aid understanding, graphs and tables to illustrate performance data
发表于 2009-10-24 19:18:31
发表于 2023-8-4 10:57:33
海川化工论坛网(hcbbs) @Discuz! X3  加载0.680323 second(s), 105 queries Redis On.
