[ASPEN] 请教aspen warning 问题
6.2K |2
biubiub_Bt9llVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP山东省
请问出现这个是什么意思呀
The following Unit Operation blocks were
completed with warnings:
B3
Properties estimation was never executed
The following messages were issued during Input Translation:
*  WARNING IN THE 'PROP-DATA' PARAGRAPH WHICH BEGINS ON LINE 52
   FIRST ID: PURE-1
   PARAMETER NAME PARC IS NOT REQUIRED IN ANY PHYSICAL PROPERTY MODELS
   IN THIS SIMULATION.  THE INPUT PROP-DATA WILL BE IGNORED.
发表于 2020-5-14 21:46:47
xiamingteda + 3 发起议题
当前内容由会员用户名 biubiub_Bt9ll 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
HigeeVIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
可以直接忽略
发表于 2020-5-17 11:44:42
你需要估计物性吗?意思是你并不需要PARC这个物性,因而物性数据被忽略了
发表于 2020-5-18 14:44:47
海川化工论坛网(hcbbs) @Discuz! X3  加载0.114036 second(s), 62 queries , Redis On. | 网站统计 |
