四川久远
[推荐] Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry
3.1K |13
mingechenVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP台湾省
加入千万工业人行列
Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry 1st ed. 2017 Edition by Alec Groysman
This book addresses corrosion problems and their solutions at facilities in the oil refining and petrochemical industry, including cooling water and boiler feed water units. Further, it describes and analyzes corrosion control actions, corrosion monitoring, and corrosion management. Corrosion problems are a perennial issue in the oil refining and petrochemical industry, as they lead to a deterioration of the functional properties of metallic equipment and harm the environment – both of which need to be protected for the sake of current and future generations. Accordingly, this book examines and analyzes typical and atypical corrosion failure cases and their prevention at refineries and petrochemical facilities, including problems with: pipelines, tanks, furnaces, distillation columns, absorbers, heat exchangers, and pumps. In addition, it describes naphthenic acid corrosion, stress corrosion cracking, hydrogen damages, sulfidic corrosion, microbiologically induced corrosion, erosion-corrosion, and corrosion fatigue occurring at refinery units. At last, fouling, corrosion and cleaning are discussed in this book.
Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry 1st .rar ( 下载次数: 3,容量8.41 MB,共需【3  财富值  +  财富 -5 财富值】)
发表于 2018-2-14 07:01:31
参与人数 1财富 +25 收起 理由
亚梅 + 25 资料文件共享
当前内容由会员用户名 mingechen 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
kafei-12VIP会员 VIP会员 | 显示全部楼层       最后访问IP广东省
谢谢分享!
发表于 2018-2-21 08:28:07
王根荣 + 5 春节快乐!
kyzy_560VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
谢谢分享!
发表于 2018-2-24 07:59:07
参与人数 1财富 +1 收起 理由
王根荣 + 1 积极参与
yangzhi1VIP会员 VIP会员 | 显示全部楼层       最后访问IP江苏省
在哪里能得到这本书,楼主能分享一下吗?
发表于 2018-3-11 10:00:33
王根荣 + 5 积极参与
dengby88VIP会员 VIP会员 | 显示全部楼层       最后访问IP福建省
学习学习!!!
发表于 2019-9-15 20:17:44
王根荣 + 3 积极参与
andyli2003123VIP会员 VIP会员 | 显示全部楼层       最后访问IP广东省
发表于 2019-9-23 11:07:20
binghexinshiVIP会员 永久VIP | 显示全部楼层       最后访问IP江苏省
楼主,你这个压缩文件有没有放全?
发表于 2019-9-23 19:15:16
王根荣 + 5 积极参与
发表于 2019-9-23 19:19:31
王根荣 + 3 积极参与
janeeyreliuVIP会员 VIP会员 | 显示全部楼层       最后访问IP天津市
学习一下
发表于 2019-9-26 18:49:00
亚梅VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
海川大学四年  |  头衔:  【一线技术人员】
学习学习!!!
发表于 2019-9-27 09:36:43
julius6054VIP会员 VIP会员 | 显示全部楼层       最后访问IP广西壮族自治区
全是英文,看着提费劲了啊
发表于 2019-9-29 10:18:00
王根荣 + 5 积极参与
tianleikkkVIP会员 VIP会员 | 显示全部楼层       最后访问IP河南省
发表于 2020-2-12 21:03:25
王根荣 + 5 积极参与
Corrosion Problems and Solutions in Oil Refining and Petrochemical Industry  [复制链接]
发表于 2020-6-19 10:14:46
发表于 2020-6-21 20:52:13
王根荣 + 5 积极参与
海川化工论坛网(hcbbs) @Discuz! X3  0.332747 second(s), 161 queries , Redis On.
