[讨论帖] 压缩机专业词汇
2.4K |5
容积式压缩机 positive displacement compressor
往复式压缩机(活塞式压缩机) reciprocating compressor
回转式压缩机 rotary compressor
滑片式压缩机 sliding vane compressor
单滑片回转式压缩机 single vane rotary compressor
滚动转子式压缩机 rolling rotor compressor
三角转子式压缩机 triangle rotor compressor
多滑片回转式压缩机 multi-vane rotary compressor
滑片 blade
旋转活塞式压缩机 rolling piston compressor
涡旋式压缩机 scroll compressor
涡旋盘 scroll
固定涡旋盘 stationary scroll, fixed scroll
驱动涡旋盘 driven scroll, orbiting scroll
斜盘式压缩机(摇盘式压缩机) swash plate compressor
斜盘 swash plate
摇盘 wobble plate
螺杆式压缩机 screw compressor
单螺杆压缩机 single screw compressor
阴转子 female rotor
阳转子 male rotor
主转子 main rotor
闸转子 gate rotor
无油压缩机 oil free compressor
膜式压缩机 diaphragm compressor
活塞式压缩机 reciprocating compressor
单作用压缩机 single acting compressor
双作用压缩机 double acting compressor
双效压缩机 dual effect compressor
双缸压缩机 twin cylinder compressor
闭式曲轴箱压缩机 closed crankcase compressor
开式曲轴箱压缩机 open crankcase compressor
顺流式压缩机 uniflow compressor
逆流式压缩机 return flow compressor
干活塞式压缩机 dry piston compressor
双级压缩机 compound compressor
多级压缩机 multistage compressor
差动活塞式压缩机 stepped piston compound compressor, differential piston compressor 串轴式压缩机tandem compressor, dual compressor
截止阀 line valve, stop valve
排气截止阀 discharge line valve
吸气截止阀 suction line valve
部分负荷旁通口 partial duty port
能量调节器 energy regulator
容量控制滑阀 capacity control slide valve
容量控制器 capacity control
消声器 muffler
联轴节 coupling
曲轴箱 crankcase
曲轴箱加热器 crankcase heater
轴封 crankcase seal, shaft seal
填料盒 stuffing box
轴封填料 shaft packing
机械密封 mechanical seal
波纹管密封 bellows seal
转动密封 rotary seal
迷宫密封 labyrinth seal
轴承 bearing
滑动轴承 sleeve bearing
偏心环 eccentric strap
滚珠轴承 ball bearing
滚柱轴承 roller bearing
滚针轴承 needle bearing
止推轴承 thrust bearing
外轴承 pedestal bearing
臼形轴承 footstep bearing
轴承箱 bearing housing
止推盘 thrust collar
偏心销 eccentric pin
曲轴平衡块 crankshaft counterweight, crankshaftbalance weight
曲柄轴 crankshaft
偏心轴 eccentric type crankshaft
曲拐轴 crank throw type crankshaft
连杆 connecting rod
连杆大头 crank pin end
连杆小头 piston pin end
曲轴 crankshaft
主轴颈 main journal
曲柄 crank arm, crank shaft
曲柄销 crank pin
曲拐 crank throw
曲拐机构 crank-toggle
阀盘 valve disc
阀杆 valve stem
阀座 valve seat
阀板 valve plate
阀盖 valve cage
阀罩 valve cover
阀升程限制器 valve lift guard
阀升程 valve lift
阀孔 valve port
吸气口 suction inlet
压缩机气阀 compressor valve
吸气阀 suction valve
排气阀 delivery valve
圆盘阀 disc valve
环片阀 ring plate valve
簧片阀 reed valve
舌状阀 cantilever valve
条状阀 beam valve
提升阀 poppet valve
菌状阀 mushroom valve
杯状阀 tulip valve
缸径 cylinder bore
余隙容积 clearance volume
附加余隙(补充余隙) clearance pocket
活塞排量 swept volume, piston displacement
理论排量 theoretical displacement
实际排量 actual displacement
实际输气量 actual displacement, actual output of gas
气缸工作容积 working volume of the cylinder
活塞行程容积 piston displacement
气缸 cylinder
气缸体 cylinder block
气缸壁 cylinder wall
水冷套 water cooled jacket
气缸盖(气缸头) cylinder head
安全盖(假盖) safety head
假盖 false head
活塞环 piston ring
气环 sealing ring
刮油环 scraper ring
油环 scrape ring
活塞销 piston pin
活塞 piston
活塞行程 piston stroke
吸气行程 suction stroke
膨胀行程 expansion stroke
压缩行程 compression stroke
排气行程 discharge stroke
升压压缩机 booster compressor
立式压缩机 vertical compressor
卧式压缩机 horizontal compressor
角度式压缩机 angular type compressor
对称平衡型压缩机 symmetrically balanced type compressor
1. performance parameter性能参数——表征压缩机主要性能的诸参数,如:气量、压力、温度、功率及噪声、振动等
2 constructional parameter结构参数——表征压缩机结构特点的诸参数,如:活塞力、行程、转速、列数、各级缸径、外形尺寸等
3 inlet pressure/suctionpressure吸气压力(吸入压力)——在标准吸气位置气体的平均绝对全压力。
4 inlet pressure of acompressor/suction pressure of a compressor进气压力 ——压缩机第1级的吸气压力称为进气压力
5 discharge pressure排气压力(排出压力)——在标准排气位置气体的平均绝对全压力
6 discharge pressure of a compressor输气压力 ——压缩机末级的排气压力称为输气压力 7 rated pressure额定压力 ——符合有关标准、合同或铭牌规定的压力
8 nominal pressure名义压力
9 nominal pressure公称压力——不顾及各种影响,作为分级标准或初步设计计算的压力值
10 stage pressure ratio级压力比——级的排气压力与其吸气压力之比值
11 total pressure ratio全压力比
12 overall pressure ratio总压力比——压缩机的输气压力与其进气压力之比值
13 pressure loss压力损失 ——在流体的流动过程中,因存在各种阻力造成的
压力降
14 actual pressure实际压力 ——压缩机在运行过程中的瞬时压力值
15 inlettemperature/suction temperature吸气温度——在标准吸气位置气体的全温度
16 inlet temperature ofa compressor/suction temperature of a compressor进气温度 ——压缩机第1级的吸气温度称为进气温度
17 discharge temperature排气温度 ——在标准排气位置气体的全温度
18 discharge temperatureof a compressor输气温度 ——压缩机末级的排气温度称为输气温度
19 capacity排气量(容积流量)——经压缩机某级压缩并排出的气体,在标准排气位置的气量,换算到进气温度、进气压力及其组分(例如湿度)时的值
20 capacity of a compressor输气量(压缩机实际容积流量)——压缩机末级的排气量称为输气量
21 standard capacity标准输气量(压缩机标准容积流量)——输气量换算到标准工况(温度和压力)时的值
22 rotational speed旋转速度(旋转频率)
23 rotational speed/rotations per minute/rotational frequency转速——轴驱动的压缩机主轴,在单位时间内的旋转数
24 outer dead point外止点 ——活塞向盖或外端行程的极限位置
25 inner dead point内止点——活塞向轴或体内行程的极限位置
26 stroke行程 ——活塞上的某一点,从外止点移到内止点时的距离
27 clearance volume余隙容积 ——活塞在止点时,气缸内可以容纳残留气体的容积值
28 stroke volume/sweptvolume行程容积——活塞在一个行程中所扫气的容积值
29 relative clearance volume相对余隙容积——余隙容积与行程容积之比值
30 work volume工作容积(气缸容积)——行程容积与相应余隙容积之和值
31 balancing volume平衡容积——压缩机的某一列中,仅起到平衡气体压力所产生活塞力作用的通气腔容积值
32 cylinder diameter缸径 ——气缸包容活塞处的直径
33 stroke–bore ratio行程–缸径比 ——行程与缸径之比值
34 crank radius曲柄半径——曲轴主轴颈轴线与曲柄销轴线间的距离
35 length of connecting rod连杆长度——连杆大、小头孔轴线间的距离
36 ratio of crank radius to length of connecting rod 连杆比——曲柄半径与连杆长度之比值 37 mean pistons peed活塞平均速度——单位时间内活塞瞬时速度的平均值 4.
38 高速性系数 — Sn2 m(r/min)2 行程与二次方转速的乘积值
39 coefficient ofcapacity输气系数(容积效率)——输气量与对应时间内第一级的行程容积之比值
40 pressure coefficient压力系数——计及吸气压力因流动及脉动而降低后与原吸气压力之比值
41 volume coefficient容积系数——计及余隙容积内压缩介质的膨胀,表征行程容积吸气效率的系数
42 heating coefficient加热系数
43 Temperature coefficient温度系数——计及吸气过程中的气体被加热,表征行程容积利用程度的系数
44 gas seal coefficient气密系数
45 gas leak coefficient泄漏系数——计及气缸部分各部位压缩介质的泄漏,表征吸入气量利用程度的系数
46 condensate coefficient凝析系数
47 humidity coefficient湿度系数——计及压缩机第1级吸入了经压缩–冷却后会凝析的湿气,对后面各级的工况影响程度的系数
48 exhaust coefficient抽气系数(加气系数)——在工艺流程用压缩机中,计及其级间的抽气或加气情况,对确定下一级行程容积影响的系数
49 compressibility coefficient压缩性系数
50 compressibilitycoefficient压缩因子——表征实际气体状态与理想气体状态差异的无量纲因子
51 distance of the row to row/distance of the line to line列间距——相邻气缸其平行轴线间距离
1. crankshaft piston compressor 曲轴活塞压缩机(活塞压缩机)——具有曲轴旋转运动的压缩机
2. reciprocating compressor without crankshaft 无曲轴压缩机(无轴压缩机)——没有曲轴或轴的旋转运动的压缩机
3. shaft pistoncompressor 轴活塞压缩机(斜盘压缩机)——活塞轴线平行于动力输入轴轴线,且均布于其周围的压缩机
4. diaphragm compressor 隔膜压缩机(膜片压缩机)——机械直接或液压驱动膜片,完成压缩循环的压缩机
5. gas compressor 气体压缩机(压气机)——压缩介质除空气外的其他气体,也可包括空气的压缩机之统称
6. air compressor 空气压缩机(压风机)——压缩机介质为空气的压缩机
7. general purpose compressor/all purpose compressor/compressorfor pressed air/pressed–air compressor 动力用压缩机——为气动机械和气动工具提供动力气源的压缩机
8. process compressor 工艺流程用压缩机(流程压缩机)——石油、化工等工艺流程用的压缩机
9. compressor for ship purpose 船用压缩机——专用于舰船的压缩机
10. filling compressor 充瓶用压缩机(充瓶压缩机)——用于压缩介质装瓶的压缩机
11. multi–purpose compressor/multi–service compressor 联合压缩机——同一台压缩机中,各气缸分别压缩多种工质且非前后级关系的压缩机
12. combined compressor/combination compressor复合压缩机(串联压缩机)——同一压缩机中,分别采用不同类型的压缩机,形成前后级关系,达到提高介质压力的压缩机
13. motorcompressor/gas–engine compressor 摩托压缩机
14. integral compressor/motor compressor 整体压缩机(摩托压缩机)——与往复式原动机部分地共用一个运动机构的压缩机。对用煤气机驱动的运动机构共用程度较少的压缩机,亦称摩托压缩机
15. free piston compressor 自由活塞压缩机——内燃动力通过对动活塞直接压缩工质的无曲轴压缩机,活塞的返程和同步,利用气垫作用和同步机构来完成
16. compressor with electro-magnetically actuated piston 电磁驱动活塞压缩机(电磁压缩机)——交变磁场的磁力直接驱动活塞作往复直线运动来完成压缩循环的压缩机
17. mini type compressor 微型压缩机——一般指功率不大于15 kW,额定压力不大于1.4MPa的空气压缩机
18. stationary compressor 固定式压缩机(固定的压缩机)——固定在基础上的压缩机
19. portable compressor 移动式压缩机(移动的压缩机)——指便携的或具有移动装置的压缩机
20. skid mounted compressor 撬装压缩机(块装压缩机)——固定在撬座上的压缩机
21. no–foundationcompressor 无基础压缩机——装有吸振装置,不需基础的压缩机
22. packaged compressor 罩式压缩机(箱装压缩机)——设置有封闭罩壳,将主机、驱动机及附属设备等罩盖,构成独立的机组
23. water cooled compressor水冷式压缩机——压缩介质由水进行冷却的压缩机
24. air–cooledcompressor 风冷式压缩机(气冷式压缩机)——压缩介质由空气冷却的压缩机
25. mixed–cooling compressor 混冷式压缩机——压缩介质由(空)气和液体分别冷却的压缩机
26. compressor withcrosshead 有十字头压缩机——具有十字头的压缩机
27. compressor withoutcrosshead 无十字头压缩机——没有十字头的压缩机 28.non–lubricated compressor/dry–up compressor干运转压缩机(无润滑压缩机)(无油压缩机)活塞和气缸间为干运转的压缩机
29. labyrinth compressor 迷宫压缩机——以迷宫密封压缩介质的压缩机
30. booster compressor 增压压缩机(加压机)——有压力(不小于0.1MPa)的系统中,进一步提高介质压力的压缩机
31. recycle compressor 循环压缩机(循环机)——压缩介质自排气口排出后,其部分或全部通过一定的系统后,重返至吸气口,且全压力比不大于2的压缩机
32. variable-stage compressor 变级压缩机(变工况压缩机)——改变压缩级数,以适应气量或压力大幅度改变需要的压缩机
33. single-acting compressor单作用压缩机(单动式压缩机)——仅在活塞的一端(面)与气缸组成行程容积的压缩机
34. double acting compressor双作用压缩机(复动式压缩机)——在活塞的两端(面)均与气缸组成行程容积的压缩机
35. low pressurecompressor 低压压缩机——额定压力不大于1.0MPa的压缩机
36. medium pressurecompressor 中压压缩机——额定压力大于1.0MPa至10MPa的压缩机
37. high–pressure compressor 高压压缩机(高压机)——额定压力大于10MPa至100MPa的压缩机
38. ultra-high-pressure compressor 超高压压缩机——额定压力大于100MPa的压缩机39. single-stage compressor 单级压缩机——级数为1的压缩
1) compressed medium 压缩介质(介质、工质)—— 被压缩的工质(气体)
2) stage 级——完成压缩循环的基本单元
3) 段——在一台工艺流程用压缩机中,相邻各级的气量和组分相同时,称为段
4) line (row) 列——在同一气缸轴线上的单个气缸或串联气缸,结构上组成一列
5) bare compressor 主机——压缩机的机体部分和压缩部分的总称
6) driver 驱动机(原动机)——驱动压缩机的动力机械或装置
7) auxiliary equipments 附属设备(辅机)——除主机和驱动机外,其余设备的总称
8) frame and moving parts 机体部分(基础部分)——压缩机的机身或曲轴箱和运动部件等的总称
9) compressingcomponents 压缩部分(气缸部分)—— 压缩机的气缸、活塞、气阀和填料函等部件的总称
10) variable-type 变型——对原型机的结构作局部变更,在其型号中标有―结构差异‖者,称为原型机的变型
11) variant 派生——原型机的机体部分基本不变或其型号中的―结构‖不变,而―特征‖和(或)性能参数及特性或介质改变者,称为原型机的派生
12) inter-cooling 中间冷却(级间冷却)—— 导走级间压缩介质的热量
13) after coling 后冷却——导走完成压缩后的压缩介质的热量
14) liquid injection cooling 喷液冷却——向压缩介质中喷液以降低介质温度
15 ideal compressor 理想压缩机——无余隙容积、无泄漏、亦无压力损失现象的压缩机
往复式压缩机专业词汇中英文对照
2) 往复式压缩机数据单站专业词汇中英文对照.自己收集的.我还在整理离心式压缩机的对照表.很快发表,希望大家支持拉.
Terminology InReciprocating Compressors Datasheet driver nameplate kw 驱动机铭牌功率
kw no negative tolerance applies 无负偏差
Max acceptable piston speed 活塞最大最高许用速度
Pulse device 脉动抑制装置
pulse suppress Inlet 压力脉动抑制装置进口处
Certified PT 保证点
Pressure at cylinder flange 在汽缸法兰处压力
3) Compressibility 压缩系数(压缩比)
TEMP ADIABATIC 绝对温度
as built 竣工
proposal 投标
Total Bkw at compressor shaft 总功率kw在压缩机轴处
Capacity for NNT 无负偏差的容积流量
Even minute traces 仅有微量
Elevation 海拔高度
at grade level 级水准
winterization required 要求防冻
Partial Sides 部分侧墙
Electrical Classification 电器分类
Class ____ Group ____Zone 区____组_____级
Main unit 主机
L.O Console润滑油站
CW Console 冷却水站
POCKETS/Valves Operation余隙腔/阀门开启
Type Unloaders, Plug/Finger 卸荷器类型 塞式/指式
Combined Rod Load C 综合活塞杆负荷(压缩
Combined Rod Load T 综合活塞负荷 (拉伸)
Auto Loading DelayInterlock 自动负荷 延迟联锁
Outboard bearing 外置轴承
4) Slide base for driver 电机导轨座
Sole plate for driver 驱动机底座
Key less drv 无键驱动
Quilt shaft 套筒轴
Drive Guard 传动装置护罩
Compressor Valves Dynamic Response 压缩机气阀动态响应
skid, soleplate, baseplate 底架,底版,底座
leveling screw 调节螺钉
Column mouting 立柱安装
Bolts or Studs for soleplate to frame用于机身和底板的螺栓或双头螺栓
Rail 导轨
Chock block 垫块 垫片
shims direct grounted 直接灌浆
Cement/Mortar Grout水泥/沙浆浇灌
off mounted 分别安装
Flange finish 法兰光洁度
Inlet strainer 进气过滤器
manifold piping 集合管
spool piece for inletstrainer 进气过滤器套筒
5) Match marked 配合标记
One CMMN to all unites 所有设备共用一个
Dual filters with transfer valves带转换阀的双联过滤器
Seperated machine mounted panel 独立的机器安装控制盘
Seperated free standing panel 独立的自由防止控制盘
Cyl. LUBRICATORS 汽缸注油器
Hydraulic tension tools 液压安装工具
US Customary Units 美国常用单位
Barring device 盘车装置
Instrument air 仪表风
Single or double acting 单作用或双作用
Bore 缸径
Stroke 行程
Cylinder Liner 钢套
Piston displacement 活塞排量
Volumetric efficiency 容积效率
Liner nominal thickness 钢套公称厚度
Rod REV DEGREE 活塞反向角
Facing 法兰面
Wear bands 支撑环
Thread roots stress 螺纹根部应力
6) Gas configuration 气体组态
purge 清除
simulation 模拟、仿真
steady state 稳态
transient 动态
transient restart 动态再启动
scenario 方案
trend plot 趋势图
interactive 交互式的
simulation 模拟
compressor 压缩机
generic compressor 简单压缩机
centrifugal compressor 离心压缩机
reciprocating compressor 往复式压缩机
adiabatic efficiency 绝热效率
mechanical efficiency 机械效率
driver 驱动机
generic driver 简单驱动机
turbine driver 燃气轮机
fuel Xreg 燃料供给
ambient temperature 环境温度
auxiliary load 附加载荷
status 状态
mode 模式
mode swapping 模式转换
bypass/free flowing 旁通
setpoint 设定值
constraint 限制、约束
connection 连接、关系
trend 趋势
pressure 压力
speed 转速
head 压头
inventory 管存
velocity 流速
overall heat transfer coefficient 总传热系数
burried depth 埋深
unit 单位
mass 质量
volume 体积
ensity 密度
heating value 热值
heat capacity 热容
line pack 充装
rated heat rate 额定耗热率
rated fuel usage 额定燃料利用率
resistance coefficient 阻力系数
temperature 温度
flow rate 流量
mass flow rate 质量流量
actual flow rate 实际流量
accumulated volume 累积体积
elevation 高程
specific heat 比热
thermal conductivity 导热系数
viscosity 粘度
specific gravity 比重、密度
fluid 流体
maximum 最大的
minimum 最小的
surge 喘振
stonewall 滞止
convergence 收敛
orthogonal 直角的、直交的
toggle 切换
grid 格子
cylinder 汽缸
DPID 驱动机性能曲线
CPID 压缩机性能曲线
TPID 燃气轮机性能曲线
performance curve 性能曲线
disconnect 断开
data block 数据块
standard conditions 标况
upstream 上游
downstream 下游
node 节点
pipe 管段
diameter 直径
length 长度
wall thickness 壁厚
roughness 粗糙度
gas equation 气体方程
knot spacing 空间步长
carbon dioxide 二氧化碳
supply 气源、进气点
delivery 分输点
valve 阀门
check valve 单向阀、止回阀
block valve 截断阀
regulator valve 调解阀
gate valve 闸阀 公式中符号
: Reynolds Number 雷诺数
absolute roughness 绝对粗糙度
internal diameter 内径
Outside diameter of pipe管外径
gas density/density of the gas 气体密度
universal gas constant 通用气体常数
compressibility factor 压缩因子
Z molecular weight of gas 气体分子量
gauge pressure 表压
Absolute pressure 绝对压力
compression ratio 压比
length of the pipe 管段长度
time 时间
cross-sectional area ofthe pipe 管子的横截面积
velocity of the gas 气体流速
acceleration due to gravity 重力加速度
elevation of pipe 管道的高程
suction/discharge temperature 进/出口温度
rated power 额定功率
shaft power 轴功率
inlet actual volumetricflow 入口实际体积流量
adiabatic head 绝热压头
Design safety factor 设计安全系数
F Longitudinal joint safety factor 焊缝安全系数
E Temperature derating factor 温度折减系数
Yield strength 屈服强度
Steel pipe 刚性管
Plastic pipe 弹性管
liquid configuration 液体组态
pump
发表于 2017-6-13 08:45:44
参与人数 3财富 +21 收起 理由
B0SS + 10 资料文件共享
天净沙小李 + 5 给力
海蓝之乡 + 6 发起议题
当前内容由会员用户名 955559 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
学习了,英文单词
发表于 2017-6-13 08:47:52
感谢分享!
发表于 2017-6-13 09:09:04
这个很好,现在很多外国的机组都是原装的PLC画面,搞得操作工很为难,建议各装置有这种情况的让厂家或者仪表翻译掉。关于此贴,一般还有个联锁报警的表格,那个翻译一下,对操作工的知道和熟悉中控画面很有必要
发表于 2017-6-13 14:56:20
海川副教授  |  头衔:  【海川活跃分子】
自己从来没有想过整理归类,这么全面,谢谢啦。
发表于 2017-6-13 18:43:11
defeilVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
厉害,翻译好专业,好全面,学习收藏了,用ASPEN做压缩机动态模拟的时候估计能用到,谢谢啦
发表于 2017-6-14 10:25:05
海川化工论坛网(hcbbs) @Discuz! X3  加载0.168667 second(s), 67 queries , Redis On. | 网站统计 |
