调节阀压降的选取
21.2K |45
jindou0727VIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
我也一直被这个问题困扰,在阀门CV值计算的时候,这是一个很关键的参数,经常是根据阀门的大小反算回去的,希望有高人指点一下
发表于 2009-6-7 18:38:42
chinazwr + 4 积极参与
明1982VIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
有没有具体的资料可以学习一下
发表于 2009-6-7 20:40:30
GGYYGGVIP会员 VIP会员 | 显示全部楼层       最后访问IP天津市
调节阀压降是根据阀前压力与阀后压力确定的.跟管线的压力也有关系.
发表于 2009-6-10 21:27:56
chinazwr + 4 积极参与
JLMTLVIP会员 VIP会员 | 显示全部楼层       最后访问IP加拿大–安大略省–哈密尔顿–哈密尔顿CIK
下面的连接会有些建议。
http://www.cheresources.com/valvezz.shtml
发表于 2009-6-11 05:04:00
bastia2004 + 6 资料文件共享
bastia2004楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP江苏省
楼上的链接相关内容如下:
STEP #2:  Define a maximum allowable pressure drop for the valve
When defining the allowable pressure drop across the valve, you should first investigate the pump.  What is its maximum available head?  Remember that the system pressure drop is limited by the pump.  Essentially the Net Positive Suction Head Available (NPSHA) minus the Net Positive Suction Head Required (NPSHR) is the maximum available pressure drop for the valve to use and this must not be exceeded or another pump will be needed.  It's important to remember the trade off, larger pressure drops increase the pumping cost (operating) and smaller pressure drops increase the valve cost because a larger valve is required (capital cost).  The usual rule of thumb is that a valve should be designed to use 10-15% of the total pressure drop or 10 psi, whichever is greater.  For our system, 10% of the total pressure drop is 15 psi which is what we'll use as our allowable pressure drop when the valve is wide open (the pump is our system is easily capable of the additional pressure drop).
这个也是从动力消耗方面来考虑的,采用10-15%的系统压降。
发表于 2009-6-11 05:11:48
Nicksun + 5 深入讨论
由于只负责提供工艺条件,有些具体的计算不了解,比如说,如果我给仪表专业提的压降太小,比如说10kpa,是不是不行?
发表于 2009-6-12 19:52:05
xinht1 + 2 深入讨论
调节阀压降太低会造成调节精度不够,阀体过大成本高等缺点。个人认为,如果实在提不出准确条件,可以将正常流量下得压降定为70kPa。
如果本论坛没有相关讨论,建议1.参考上面的连接网站,现注册再搜索相关讨论。这是北美主要化工论坛之一,有几位人物水平很高。2.从fisher网站下载control valve handbook,应该有很大帮助。
发表于 2009-6-12 21:01:09
参与人数 1财富 +12 收起 理由
bastia2004 + 12 帮助他人解决问题
xiaoxian297VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
按目前我的了解。对于阀门的压降起码有两种情况:
1.泵送系统上。压降可以按系统允许压降的10%-15%,或30-50%来取。跟人感觉前者靠谱点。
2.非泵系统。由前后系统的压力决定。压降可以非常大或非常小
发表于 2009-10-12 17:41:20
xinht1 + 3 深入讨论
jlchinaVIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
1# bastia2004
调节阀的压降通常取该管路系统允许压降的30%~40%,一般至少3~5米液柱
SSEC123 发表于 2009-6-6 21:24
压降“管路系统允许压降的30%~40%”是正确的,“一般至少3~5米液柱”则未必是正确的。
同样
“工艺专业给仪表专业提调节阀条件时,压降是必须填的数据。如果单纯根据经验,不计算的话,一般写50Kpa”也未必正确。
理由如下:
1.管路不同,本身总压降是有区别的
2.如果是真空管路,绝压本身可能小于“50kPa、3~5米液柱”
3.有的塔顶自回流,一般冷凝器高于塔顶2米左右是很正常的
发表于 2009-12-3 13:06:16
xinht1 + 5 深入讨论
冰玉蓝神VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
调节阀进气压力一般在2.5公斤左右不能低于2公斤
发表于 2009-12-3 18:44:07
xinht1 + 3 深入讨论
wwggwlsr1985VIP会员 VIP会员 | 显示全部楼层       最后访问IP北京市
这东西真的挺麻烦的啊!
发表于 2010-1-29 11:01:15
xinht1 + 3 深入讨论
快乐工作VIP会员 VIP会员 | 显示全部楼层       最后访问IP北京市
搞设计的哥们,这个可不能仅仅根据经验,有时经验害死人啊,举个例子:
汽包液控调节阀在选型时就根据经验选择的阀前后压降为0.5公斤,可是实际上该阀阀前压力为6.4MPa,阀后压力为2.8MPa,结果投用后汽包液位无法控制,害的操作人员只能靠手动开关调节阀前后手阀,而且阀门在3层平台,大冬天的,冷啊。
发表于 2010-2-1 16:52:01
xinht1 + 3 深入讨论
seefarVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
按照Coulson & Richardson's Chemical Engineering说法
对于一般的液体系统,取管道总阻力的30~50%,但不低于50kPa.
发表于 2010-2-2 13:23:03
xinht1 + 3 深入讨论
汽包液控调节阀在选型时就根据经验 ...
快乐工作 发表于 2010-2-1 16:52
    这位同学说举的例子很好,调节阀压降的具体计算过程,可以参考《化工厂系统设计(第二版)》里的,调节阀选用原则。。。
发表于 2011-12-25 16:28:46
xinht1 + 3 深入讨论
zhongrr007VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
1、29楼提到的fisher网站是指哪个网站?
2、control valve handbook在哪里下啊?
3、《化工厂系统设计(第二版)》哪里下啊?
4、Coulson & Richardson's Chemical Engineering有木有啊?
发表于 2012-2-8 17:34:26
xinht1 + 2 深入讨论
sunxuanjuVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
实习版(海友)  |  头衔:  【海川资深技术人员】
这个问题,刚刚有个老工程师认真的教了我一下,受益匪浅,这里和大家分享一下:
1.是否只是填写一个经验数据,比如说30,59,70kpa
   不可以,压降必须根据工况,和总管路的压降来确定,不可以只填30~70kPa,而且这几个数值和真正的情况比也偏小。
2、如果按照调节阀压降/管路系统压降计算的话,这里填写的是什么时候的压降,因为对应的流量应有三种:最小/正常/最大;
  三种工况下的压降都要填,标准的表格就是这样的
3、调节阀压降/管路系统压降=? 这个比值是根据什么确定下来的,如果说介质、压力不同,那么这个比值应该不会一样吧,为什么有的书只写0.3这一个数?
  通常是0.3到0.5,但有一个做法是,当控制阀的压降占总压降的比例不同时,选择的控制阀的类型不一样,线性或等百分比。附件是一个说明。
发表于 2012-2-9 13:36:36
ControlValveCharacteristicSel.pdf
43.83 KB, 下载次数: 3, 下载积分:财富 -5 财富值
另需要【10  财富值】  [记录]  [预览]
xinht1 + 6 深入讨论
dengjiandunVIP会员 VIP会员 | 显示全部楼层       最后访问IP广西壮族自治区
应该填写正常流速,设计厂家会根据你的正常流速设计一个流量范围,就是出最大值和最小值。数据就要根据这个正常值选一个数据填写啦。调节阀的压降/管路系统压降=0.3,这只是在常压的情况下使用,像一些特殊的管道如压力或低压管道,还是要专门进行核算的。
发表于 2012-2-9 14:50:57
xinht1 + 3 深入讨论
lismeVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
这问题也很困惑,太大了不利于节能,太小了调节不精确,给个准确数据好难啊,,,
发表于 2016-5-4 08:41:55
xinht1 + 2 深入讨论
濠梁知乐VIP会员 VIP会员 | 显示全部楼层       最后访问IP北京市
调节阀的压降/管路系统压降≤0.3时,调节阀特性畸变严重,管道流量大小更多是有管道阻力决定的,从自控角度来说,该管道流量不易控制,应当重新配管。
关于50kPa的调节阀的压降,应当是调节阀全开时的压降。
发表于 2016-5-4 09:10:09
xinht1 + 3 深入讨论
totthnamVIP会员 VIP会员 | 显示全部楼层       最后访问IP天津市
调节阀的压降确实是比较难搞,我们通常是按15~25%总压降来设计。
发表于 2016-8-11 17:22:40
goldliyang + 2 积极参与
海川化工论坛网(hcbbs) @Discuz! X3  加载0.379524 second(s), 185 queries , Redis On.
