有没有大佬帮忙看一下这个萃取的ASPEN模型的问题要怎么解决
3.1K |1
michael_leoVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP河北省
化工小白,问题如下
->Processing input specifications ...
      STRUCTURE FOR COMPONENT N235 HAS NOT BEEN DEFINED.
      PCES CANNOT USE GROUP-CONTRIBUTION METHODS TO ESTIMATE MISSING PROPERTIES
      USE THE STRUCTURES PARAGRAPH TO DEFINE STRUCTURES OF THIS COMPONENT.
  *   WARNING IN THE "STREAM" PARAGRAPH WHICH BEGINS ON LINE 78
      STREAM NAME: EXTRA
      COMPONENT MOLE FLOWS OF SUBSTREAM: "MIXED"
      ARE NORMALIZED TO THE TOTAL MOLE FLOW VALUE.
  *   WARNING IN THE "STREAM" PARAGRAPH WHICH BEGINS ON LINE 82
      STREAM NAME: WATER
  Flowsheet Analysis :
Block $OLVER01 (Method: WEGSTEIN) has been defined to converge
         streams: 10        9         8         7
COMPUTATION ORDER FOR THE FLOWSHEET:
$OLVER01 B1 B2 B3 B4 B5
(RETURN $OLVER01)
->Calculations begin ...
> Beginning Convergence Loop $OLVER01 Method: WEGSTEIN
  Converging tear streams: 10        9         8         7
   Block: B1       Model: DECANTER
  *   WARNING
      NO PHASE SPLITTING OCCURS AT GIVEN SPECIFICATIONS. SINGLE PHASE
      SOLUTION IS RETURNED.
   Block: B2       Model: DECANTER
  *   WARNING
   Block: B3       Model: DECANTER
  *   WARNING
   Block: B4       Model: DECANTER
  *   WARNING
      ACTIVITY COEFFICIENT MODEL GMUFAC HAS MISSING PARAMETERS:
      UNIFAC GROUP STRUCTURAL INFORMATION PARAMETER, UFGRP (DATA SET 1),
      MISSING FOR COMPONENT N235; NO UFGRP PARAMETERS SUPPLIED BY USER;
      DEFAULTS NOT FOUND IN DATA BANK
! Calculations stopped because of missing  property parameters
发表于 2019-8-6 16:13:51
qy576100527 + 4 发起议题
当前内容由会员用户名 michael_leo 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
michael_leo楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP河北省
里面的N235和TBP标反了
发表于 2019-8-6 16:31:56
海川化工论坛网(hcbbs) @Discuz! X3  加载0.095761 second(s), 51 queries , Redis On. | 网站统计 |
