[讨论] 联轴器moment simulator是什么
2.2K |6
dodorenVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP上海市
如题,还有idle什么的,都是做什么用的
发表于 2018-12-13 13:46:21
wawaxinxintaozi + 5 发起议题
当前内容由会员用户名 dodoren 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
dodoren楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
有知道的吗?
发表于 2018-12-18 12:03:38
午夜阳光_RWPPVIP会员 VIP会员 | 显示全部楼层       最后访问IP安徽省
英文从字面上面看是时刻模拟器的意思,具体表示什么意思就不清楚了
发表于 2018-12-18 14:52:00
wawaxinxintaozi + 5 积极参与
we11we11VIP会员 VIP会员 | 显示全部楼层       最后访问IP四川省
When do you need a special moment simulator?
For high speed turbomachinery applications with relatively small
diameter shaft mounts – say 15000 rpm with 4 inch (100 mm)
shaft mounts - a reduced moment flexible element coupling is a
must to keep the rotor sensitivity to unbalance low.
When one of these rotors needs to be balanced at speed, it’s best
to simulate the effects of the coupling mass on the end of the
rotor. This is particularly important if the rotor has an extra long
overhang from the bearing or if the rotor will otherwise operate
close to its lateral critical speed.
A one-piece “dummy” hub can be used to simulate the coupling
mass and moment, but it’s just not the same as if the actual
coupling were mounted. It’s difficult to simulate flexible element
coupling parts with a solid piece of steel.
发表于 2018-12-18 16:28:37
For high speed turbomachinery applications with relati ...
这是出自哪里,具体啥意思?能解释以下吗
发表于 2018-12-19 21:15:03
dodoren 发表于 2018-12-19 21:15
这是出自哪里,具体啥意思?能解释以下吗
我也不懂你看看这里
发表于 2018-12-20 12:27:05
kop_flex_turbomachinery_coupling_catalog.pdf
7.97 MB, 下载次数: 3, 下载积分:财富 -5 财富值
 [预览]
442159460 + 5 资料文件共享
力矩模拟器
发表于 2018-12-20 13:55:51
海川化工论坛网(hcbbs) @Discuz! X3  加载0.068209 second(s), 60 queries , Redis On. | 网站统计 |
