[求助] Aspen石灰石石膏湿法烟气脱硫模拟不能收敛,求助各位大神!!!!!!!
2.1K |0
李媛oooooVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP陕西省
Run reinitialized 16:58:38 Thu Mar 1, 2018>>
->Processing input specifications ...
      INFORMATION
      THERE ARE HENRY COMPONENTS DEFINED IN THIS CASE, THE BINARY DATABANK
      WILL BE SEARCHED AUTOMATICALLY FOR ANY AVAILABLE HENRY CONSTANTS.
      THE PAIR PARAMETERS FOR ELECNRTL OPTION SET HAS BEEN RETRIEVED FROM
      DATABANK ENRTL-RK.
      INFORMATION
      PURE COMPONENT PARAMETERS FOR SOME COMPONENTS ARE RETRIEVED FROM
      DATABANK.  THESE PARAMETERS ARE USED WITH THE ELECNRTL OPTION SET
      UNLESS YOU ENTER YOUR OWN PARAMETERS IN PROP-DATA PARAGRAPHS.
      PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT H2O
      PARAMETER PLXANT RETRIEVED FOR COMPONENT HCL
      PARAMETER CPDIEC RETRIEVED FOR COMPONENT HCL
      PARAMETER VLBROC RETRIEVED FOR COMPONENT CO2
      PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT HCL
      PARAMETER CPAQ0 RETRIEVED FOR COMPONENT SO4--
      PARAMETER PLXANT RETRIEVED FOR COMPONENT H2O
  Flowsheet Analysis :
COMPUTATION ORDER FOR THE FLOWSHEET:
FGD
->Calculations begin ...
   Block: FGD      Model: RADFRAC
       Convergence iterations:
         OL   ML   IL     Err/Tol
          1    1   10      61768.
          2    1    9      11237.
          3    1    6      4058.3
          4    1    6      1679.2
          5    1    6     0.20284E+09
          6    1    4     0.11908E+09
          7    1   10     0.40789E+06
          8    1    7      24003.
          9    1    4      11681.
         10    1    3      8074.8
         11    1    4      2386.9
         12    1    3      773.28
         13    1    3      208.27
         14    1    4      97.483
         15    1    4      62.885
         16    1    4      29.692
         17    1    3      15.051
         18    1    3      7.9273
         19    1    3      4.4862
         20    1    3      2.3654
         21    1    3      1.1870
         22    1    3     0.53698
  *** SEVERE ERROR
      THE FOLLOWING STAGES DRIED UP (VAPOR OR LIQUID FLOW APPROACHES 0):
        8
      A LIMIT OF  0.10000E-04 * SUM OF FEEDS WAS IMPOSED ON THE FLOW RATES
      OR A LIMIT OF  0.10000E-04 WAS IMPOSED ON THE STAGE V/L OR L/V RATIO.
  *** SEVERE ERROR
      SINGLE PHASE TEMPERATURE CALCULATIONS FAILED IN  11  ITERATIONS. FINAL
      TEMPERATURE IS  275.8453  FINAL ENTHALPY IS  -1.5805D+08  SPECIFIED
      ENTHALPY IS  -1.5940D+08
  **  ERROR
      BLOCK FGD IS NOT IN MASS BALANCE:
      MASS INLET FLOW = 0.15563999E+04, MASS OUTLET FLOW = 0.30488973E+04
      RELATIVE DIFFERENCE = 0.95894214E+00
->Simulation calculations completed ...
  ***  No Warnings were issued during Input Translation ***
               ***  Summary of Simulation Errors  ***
                   Physical
                   Property         System        Simulation
  Terminal Errors      0               0               0
    Severe Errors      0               0               2
           Errors      0               0               1
         Warnings      0               0
发表于 2018-3-1 17:00:48
goldliyang + 3 发起议题
当前内容由会员用户名 李媛ooooo 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.229840 second(s), 52 queries , Redis On. | 网站统计 |
