[ASPEN] 大佬们,这个设计规范怎么加呀,一直错误,可以帮帮我吗
2.9K |0
201708130101VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP山西省
我想通过调节流股11的温度使换热器HX1和HX2热负荷绝对值相等,别的流程没问题,但是设计规范收敛不了
The following Convergence blocks were
completed with errors:
$OLVER03
The following messages were issued during Input Translation:
*  WARNING WHILE CHECKING INPUT SPECIFICATIONS FOR VARIED VARIABLE IN
   DESIGN-SPEC: 'DS-1'
   YOU ARE VARYING A VARIABLE OF AN INTERMEDIATE STREAM
   STREAM RESULTS MAY BE INCONSISTENT WITH THE BLOCK UPSTREAM
   INCONSISTENT FREE WATER SETTING DETECTED FOR 2 STREAMS
   SOURCE BLOCK        FREE WATER STREAM   DESTINATION BLOCK   FREE WATER
   B8                  YES        31       ABSORBER            NO
   B7                  NO         18       B8                  YES
发表于 2021-4-19 22:53:20
qy576100527 + 4 发起议题
当前内容由会员用户名 201708130101 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.185157 second(s), 51 queries , Redis On. | 网站统计 |
