[ASPEN] 氨法脱硫过程中运行无error但是有warning.在软件的右下角显示结果是错误的
3.9K |1
qzuser_JTAOVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP山东省
[url=]图片[/url]
INFORMATION
      THERE ARE HENRY COMPONENTS DEFINED IN THIS CASE, THE BINARY DATABANK
      WILL BE SEARCHED AUTOMATICALLY FOR ANY AVAILABLE HENRY CONSTANTS.
      THE PAIR PARAMETERS FOR ELECNRTL OPTION SET HAS BEEN RETRIEVED FROM
      DATABANK ENRTL-RK.
      INFORMATION
      PURE COMPONENT PARAMETERS FOR SOME COMPONENTS ARE RETRIEVED FROM
      DATABANK ELECPURE. THESE PARAMETERS ARE USED WITH ELECNRTL METHOD.
      UNLESS YOU ENTER YOUR OWN PARAMETERS IN PROP-DATA PARAGRAPHS.
      PARAMETER MW RETRIEVED FOR COMPONENT H2SO4
      PARAMETER PC RETRIEVED FOR COMPONENT H2SO4
      PARAMETER TC RETRIEVED FOR COMPONENT H2SO4
      PARAMETER ZC RETRIEVED FOR COMPONENT H2SO4
      PARAMETER RKTZRA RETRIEVED FOR COMPONENT H2SO4
      PARAMETER VC RETRIEVED FOR COMPONENT H2SO4
      PARAMETER DGFORM RETRIEVED FOR COMPONENT H2SO4
      PARAMETER DHFORM RETRIEVED FOR COMPONENT H2SO4
      PARAMETER VLBROC RETRIEVED FOR COMPONENT NH3
      PARAMETER CPAQ0 RETRIEVED FOR COMPONENT HSO4-
      PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT H2SO4
      PARAMETER CPAQ0 RETRIEVED FOR COMPONENT SO4--
      PARAMETER PLXANT RETRIEVED FOR COMPONENT H2O
      PARAMETER VLBROC RETRIEVED FOR COMPONENT CO2
      PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT H2O
      PARAMETER PLXANT RETRIEVED FOR COMPONENT H2SO4
  *   WARNING WHILE CHECKING INPUT SPECIFICATIONS
      BLOCK NAME: RCSTR-01    MODEL NAME: RCSTR
      WHEN "TRUE-COMPS=YES" IS SPECIFIED WITH A CHEMISTRY
      PARAGRAPH, MASS BALANCE OR CONVERGENCE PROBLEMS MAY
      ARISE IF COMPONENTS PARTICIPATE IN BOTH CHEMISTRY
      AND REACTIONS.
      THE FOLLOWING EQUILIBRIUM REACTIONS ARE LINEARLY DEPENDENT IN
      REACTIONS "R-1", AND MAY CAUSE CALCULATIONS NOT TO CONVERGE:
         3
  Flowsheet Analysis :
Block $OLVER01 (Method: WEGSTEIN) has been defined to converge
         streams: RE3
COMPUTATION ORDER FOR THE FLOWSHEET:
COMPR-01 HEATE-02 PUMP-01
$OLVER01 FSPLI-02 ABSOBER FSPLI-01 COOLE-01
(RETURN $OLVER01)
FLASH-01 PUMP-02 HEATE-01 RCSTR-01 FLASH-02 CRYST-01
->Calculations begin ...
  *   WARNING WHILE PERFORMING INITIAL ENTHALPY CALCULATIONS FOR STREAM: "C1"
      ALL NON-ZERO FLOW COMPONENTS ARE HENRY COMPONENTS,
      FLASH RESULTS MAY BE INCORRECT.
   Block: COMPR-01 Model: COMPR
  *   WARNING
  *   WARNING
   Block: HEATE-02 Model: HEATER
   Block: PUMP-01  Model: PUMP
> Beginning Convergence Loop $OLVER01 Method: WEGSTEIN
  Converging tear streams: RE3
   Block: FSPLI-02 Model: FSPLIT
   Block: ABSOBER  Model: RADFRAC
       Convergence iterations:
         OL   ML   IL     Err/Tol
          1    1    3      836.36
          2    1    2      164.03
          3    1    2      94.850
          4    1    2      37.725
          5    1    1      12.958
          6    1    1      7.1381
          7    1    2      2.9943
          8    1    1      1.2257
          9    1    1     0.92378E-01
   Block: FSPLI-01 Model: FSPLIT
   Block: COOLE-01 Model: HEATER
> Loop $OLVER01 Method: WEGSTEIN     Iteration    1
# Converged              Max Err/Tol  -0.74083E+00
   Block: FLASH-01 Model: FLASH2
   Block: PUMP-02  Model: PUMP
   Block: HEATE-01 Model: HEATER
   Block: RCSTR-01 Model: RCSTR
   Block: FLASH-02 Model: FLASH2
   Block: CRYST-01 Model: CRYSTALLIZER
  *   WARNING
      OVERALL MASS BALANCE ERROR (-0.2725E-04) IS NOT WITHIN THE
      SPECIFIED TOLERANCE (0.1000E-04).
  *   WARNING
      STREAM L7 IS NOT IN CHARGE BALANCE:
      ANION FLOW = -.88686589E-01, CATION FLOW = 0.88613814E-01
      ABSOLUTE DIFFERENCE = -.72775078E-04 RELATIVE DIFFERENCE = -.82126110E-03
  *   WARNING
      STREAM L88 IS NOT IN CHARGE BALANCE:
      ANION FLOW = -.16982364E-01, CATION FLOW = 0.16909589E-01
      ABSOLUTE DIFFERENCE = -.72775078E-04 RELATIVE DIFFERENCE = -.43037756E-02
  *   WARNING
      STREAM L10 IS NOT IN CHARGE BALANCE:
      ANION FLOW = -.50237104E-03, CATION FLOW = 0.42988031E-03
      ABSOLUTE DIFFERENCE = -.72490730E-04 RELATIVE DIFFERENCE = -.16863003E+00
->Generating block results ...
->Simulation calculations completed ...
  ***  Warning(s) were issued during Input Translation ***
  ***  Check the Run Status Results for more Information ***
               ***  Summary of Simulation Errors  ***
                   Physical
                   Property         System        Simulation
  Terminal Errors      0               0               0
    Severe Errors      0               0               0
           Errors      0               0               0
         Warnings      0               0               7
工艺流程是氨水吸收二氧化硫生成亚硫酸an,又进行氧化生成硫酸an,结晶,过滤,干燥,得到产品固体硫酸an
感谢大佬,大神们。麻烦帮忙看一下,万分感谢
发表于 2019-4-15 19:17:19
原图
原图
氨法脱硫.rar
60.54 KB, 下载次数: 3, 下载积分:财富 -5 财富值
模拟bkp文件
雲目 + 5 发起议题
当前内容由会员用户名 qzuser_JTAO 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.077767 second(s), 48 queries , Redis On.
