[ASPEN] aspen
1.9K |1
疯人愿_QZUEVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP湖北省
跪求帮助!aspen怎么模拟碱洗塔,我运行的有警告怎么回事
NFORMATION
THERE ARE HENRY COMPONENTS DEFINED IN THIS CASE, THE BINARY DATABANK
WILL BE SEARCHED AUTOMATICALLY FOR ANY AVAILABLE HENRY CONSTANTS.
INFORMATION IN PHYSICAL PROPERTY SYSTEM
THE PAIR PARAMETERS FOR ELECNRTL OPTION SET HAS BEEN RETRIEVED FROM
DATABANK ENRTL-RK.
INFORMATION
PURE COMPONENT PARAMETERS FOR SOME COMPONENTS ARE RETRIEVED FROM
DATABANK ELECPURE. THESE PARAMETERS ARE USED WITH ELECNRTL METHOD.
UNLESS YOU ENTER YOUR OWN PARAMETERS IN PROP-DATA PARAGRAPHS.
PARAMETER CPDIEC RETRIEVED FOR COMPONENT HCL
PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT HCL
PARAMETER VLBROC RETRIEVED FOR COMPONENT CO2
PARAMETER PLXANT RETRIEVED FOR COMPONENT WATER
PARAMETER PLXANT RETRIEVED FOR COMPONENT HCL
PARAMETER THRSWT(ELEMENT/3) RETRIEVED FOR COMPONENT WATER
*  WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER PLXANT (DATA SET 1) FOR COMPONENT SODIU-01:
UNREASONABLE VAPOR PRESSURE CALCULATED AT NORMAL BOILING POINT.
VALUE SHOULD BE WITHIN 10% OF 1D5 N/SQM.  PLEASE CHECK YOUR INPUT
FOR THE ANTOINE PARAMETERS.
发表于 2019-4-1 17:46:18
雲目 + 3 发起议题
当前内容由会员用户名 疯人愿_QZUE 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.066755 second(s), 47 queries , Redis On.
