海奥膜
[原创] 有关整体补强知识点
1.9K |0
laternVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP山东省
国外客户经常说integrally reinforcement for opening. 此处整体补强的具体意思和形式和大家分享下:
首先查标准,万变不离其宗:
ASME VIII-1 2017 英文版 UG-37 REINFORCEMENT REQUIRED FOR OPENINGS IN SHELLS AND FORMED HEADS
关于字母F的含义:p114.
F = correction factor that compensates for the variation in internal pressure stresses on different planes with respect to the a*s of a vessel.
A value of 1.00 shall be used for all configurations except that Figure UG-37 may be used for integrally reinforced openings in cylindrical shells and cones. [See
其次,查阅以上提到的UW-16(c)(1)207.
(1) Integral reinforcement is that reinforcement provided in the form of extended or thickened necks, thickened shell plates, forging type inserts, or weld buildup
which is an integral part of the shell or nozzle wall and, where required, is attached by full penetration welds.See Figure UW-16.1 sketches (a), (b), (c), (d), (e), (f‐1),(f‐2), (f‐3), (f‐4), (g), (x‐1), (y‐1), and (z‐1) for examples of nozzles with integral reinforcement where the F factor in Figure UG-37 may be used.
最后,结合提到的图片UG-37 可看到各种整体补强形式。
可以这么理解,整体补强的接管不加补强圈。
PS:在GB150.3附录D中提到的“嵌入式接管”,英文版的GB150中翻译成了“Built-in connection pipe”。在遇到的一些国外项目产品规范中,常翻译成J Type,Q Type或者forged saddle type nozzle。
发表于 2017-10-20 10:36:02
【提示:直接搜索1853899可直达本帖。】
当前内容由会员用户名 latern 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.058908 second(s), 37 queries Redis On.
