锅炉蓄热器
1.9K |5
孙蓉VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP山东省
8.6.2        Steam accumulator: Steam flow control蓄汽器:蒸汽流量控制
In order to avoid a quick increase of the level inside of any of thesteam drums connected to the high pressure collector due to high steam flowrates up to a trip of the boiler protection by LZH-alarm of the steam drum, thesteam flow from the steam drums must be limited to the maximum permissiblevalue during the up heating phase of the steam accumulator until the steamaccumulator is connected to the steam net in normal operation condition.、
这讲的什么意思啊?
发表于 2017-6-26 17:38:29
xychao329 + 10 发起议题
当前内容由会员用户名 孙蓉 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
cywahaVIP会员 VIP会员 | 显示全部楼层       最后访问IP北京市
In order to avoid a quick increase of the level inside of any of thesteam drums connected to the high pressure collector due to high steam flowrates up to a trip of the boiler protection by LZH-alarm of the steam drum, thesteam flow from the steam drums must be limited to the maximum permissiblevalue during the up heating phase of the steam accumulator until the steamaccumulator is connected to the steam net in normal operation condition.、为了避免与高压收集器(蓄热器?)连接的汽包因为高流量(充汽)而导致液位快速升高而引发lzh报警保护,从汽包外供的蒸汽量需要限制到蓄热加热阶段的最大允许值,直到达到蒸汽管网正常运行条件。
发表于 2017-6-28 14:07:39
xychao329 + 10 积极参与
孙蓉楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
cywaha 发表于 2017-6-28 14:07
In order to avoid a quick increase of the level inside of any of thesteam drums connected to the hig ...
不理解 蓄热加热阶段最大允许值
发表于 2017-6-28 16:47:15
不理解 蓄热加热阶段最大允许值
发表于 2017-6-28 16:47:22
应该是蓄热器能够承受的最大温度和压力。
发表于 2017-12-25 17:24:21
蒸汽蓄热器必须满足蒸汽管网系统最大的蒸汽流量要求,否则负荷突然增大,会导致锅炉的炉水过度闪蒸,使得液位低于二低液位而导致锅炉报警。
发表于 2018-1-18 16:16:03
B0SS + 5 热心助人
海川化工论坛网(hcbbs) @Discuz! X3  加载0.064969 second(s), 55 queries , Redis On. 劰载中...
