[ASPEN] aspen除尘模块设计问题
1.7K |1
swpu-clzVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP四川省
Block: B1       Model: ESP
  *   WARNING
      PSD ATTRIBUTE IS NOT PRESENT IN SUBSTREAM "MIXED".
      PSD MESH OF SUBSTREAM "CIPSD" WILL BE USED WITH
      SOLIDS EVENLY DISTRIBUTED IN EACH INTERVAL.
      INFORMATION
      SUBSTREAMS ARE AT DIFFERENT TEMPERATURES.
      THERMODYNAMIC EQUILIBRIUM WILL BE ASSUMED FOR FURTHER CALCULATIONS.
      INLET STREAMS WILL BE PQ-FLASHED.
->Simulation calculations completed ...
  ***  Warning(s) were issued during Input Translation ***
  ***  Check the Run Status Results for more Information ***
               ***  Summary of Simulation Errors  ***
                   Physical
                   Property         System        Simulation
  Terminal Errors      0               0               0
    Severe Errors      0               0               0
           Errors      0               0               0
         Warnings      0               0               1
请问上面的esp出城模块的警告怎么消除?
发表于 2017-5-7 14:17:08
littlekiss + 5 发起议题
当前内容由会员用户名 swpu-clz 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
zjuvennybearVIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
有固体子物流吗?是不是没有设置颗粒分布尺寸?
发表于 2017-5-8 13:19:33
海川化工论坛网(hcbbs) @Discuz! X3  加载0.067198 second(s), 41 queries , Redis On.
