aspen出现这个是什么意思啊?求助?
4.9K |1
執筆再回首VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP四川省
The following Unit Operation blocks were
completed with errors:
B1
The following messages were issued during Input Translation:
   INFORMATION
   PURE COMPONENT PARAMETERS FOR SOME COMPONENTS ARE RETRIEVED FROM
   SDF TABLE.  THESE PARAMETERS ARE USED WITH THE ELECNRTL OPTION SET
   UNLESS YOU ENTER YOUR OWN PARAMETERS IN PROP-DATA PARAGRAPHS
   PARAMETERS RETRIEVED FOR COMPONENT H2O ARE:
      VLBROC  PLXANT
   PARAMETERS RETRIEVED FOR COMPONENT CO2 ARE:
      VLBROC
   PARAMETERS RETRIEVED FOR COMPONENT H3N ARE:
      VLBROC
   INFORMATION WHILE CHECKING INPUT SPECIFICATIONS
   BLOCK NAME: B1    MODEL NAME: RADFRAC
   AN INITIAL TEMPERATURE PROFILE SHOULD BE SPECIFIED
   IN SENTENCE 'T-EST' IF 'Q1' AND 'QN' ARE SPECIFIED.
*  WARNING WHILE CHECKING INPUT SPECIFICATIONS
   BLOCK NAME: B8    MODEL NAME: RSTOIC
   PHYSICAL PROPERTY PARAMETER DHFORM   OR DHAQFM   IS MISSING
   FOR THE FOLLOWING COMPONENTS:
       N2H8SO3     N2H8SO4
   ABSENCE OF THIS PARAMETER WILL RESULT IN INCORRECT ENTHALPY RESULTS.
   INCONSISTENT FREE WATER SETTING DETECTED FOR 4 STREAMS
发表于 2017-3-7 18:28:23
littlekiss + 10 发起议题
当前内容由会员用户名 執筆再回首 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.055857 second(s), 40 queries , Redis On.
