[PRO/Ⅱ] PRO/II计算动力粘度为什么要有这么多方法
2K |4
不是直接粘度除以密度就够了么?
为什么出来这么多方法,而且计算结果还和粘度除以密度的不一样?
O(∩_∩)O谢谢
@homingpigeon
Kinematic Viscosity  [KVIS] of Liquid Phase
Liquid viscosities are computed from the kinematic viscosity and the density. For purposes of this calculation, the density (sometimes in the form of specific gravity) is computed with the API method. In order to use this option, a KVIS method must be declared on the METHOD statement. A KVIS option is available only with the VISCOSITY(L) keyword.
KVIS methods include mixing rules that combine data for individual components to obtain a value for the bulk liquid. Each KVIS method can inter-convert between property values and index values. User-added methods may implement either or both conversions.
See Special Methods for Liquid Viscosity in the PRO/II Component and Thermophysical Properties Reference Manual for specific equations used by these methods.
See Special Stream Properties in chapter 8 of the Thermodynamic Data Keyword Manual for mixing rules used by these methods.
Simsci  This is a perturbation expansion method that uses n-alkanes as a reference system. It divides the conversions between property values and index values into 3 regions and applies a different equation in each region. For region 1: KVIS <= 0.2 cS, region 2:  0.2 <KVIS < 10000 cS,  region 3: KVIS >= 10000 cS. Based on data at two temperatures of 100F and 210F, it was developed to be well behaved when extrapolated.
UsForm  This selects a user-defined equation-based calculation method implemented in user-added subroutine SPUSER.FOR. The method returns property values (that subsequently may be converted to Index values). Refer to the topic Subroutine SPUSER in chapter 17 of the User-Added Subroutines User Guide for a discussion of implementing these methods.
Index    Uses property values of individual components to calculate an index value for each component. It then sums the indices on a weight, molar, or liquid volume basis.
UsIndex   This selects a user-defined index method implemented in user-added subroutine CVUSER.FOR. The method returns Index values (that later may be converted tp property values). Refer to the topic Subroutine CVUSER in chapter 17 of the User-Added Subroutines User Guide for a discussion of implementing these methods.
Chevron  It converts kinematic viscosities in centiStokes to an index that are blended on a liquid volume basis.
Maxwell  It converts kinematic viscosities in centiStokes to an index that are blended on a liquid volume basis. Slightly more complex correlation than the Chevron method.
Refutas  It converts kinematic viscosities in centiStokes to an index that are blended on a liquid weight basis. Similar in form to the Maxwell correlation.
NIST23 Vapor viscosities are computed using the NIST23 method.
GERG04 Vapor viscosities are computed using the GERG04 method.
发表于 2017-3-4 17:23:42
当前内容由会员用户名 longkui1990 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
chenxh123VIP会员 VIP会员 | 显示全部楼层       最后访问IP广东省
人家是专业算法
登录/注册后可看大图
发表于 2017-3-5 10:14:01
毁了多年的三观。。  详情 回复 发表于 2017-3-6 09:28
longkui1990 + 3 深入讨论
毁了多年的三观。。
发表于 2017-3-6 09:28:20
ubotecVIP会员 VIP会员 | 显示全部楼层       最后访问IP福建省
哥们,认真阅读下,这讲的是KVIS methods, not the kinematic viscosity ,是算的运动粘度的一种,不是动力粘度吧
发表于 2017-3-18 20:27:57
http://www.ubotec.com/what-is-viscosity/ 我网站的文章供参考。你理解错了
发表于 2017-3-18 20:29:25
海川化工论坛网(hcbbs) @Discuz! X3  加载0.105356 second(s), 44 queries , Redis On.
