一个fortran 子程序编译总出现错误的问题
2.7K |2
abner001VIP会员 VIP会员 | 显示全部楼层       最后访问IP北京市
有很多类似于这样的错误提示
MEM.F(1) : Error: Syntax error, found END-OF-STATEMENT when expecting one of: * <IDENTIFIER>
      SUBROUTINE ME     (NSIN,    NINFI,    SIN1,    SIN2,    SIN3,
发表于 2011-6-30 22:05:29
当前内容由会员用户名 abner001 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
nan4512VIP会员 VIP会员 | 显示全部楼层       最后访问IP湖南省
可能是FORTRAN语法错误,导致编译不通过把
发表于 2011-7-1 13:44:58
abner001楼主 VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP北京市
                    SIN4,    SINFI,    NSOUT,   NINFO,   SOUT1,
                    SOUT2,   SOUT3,    SOUT,    SINFO,   NSUBS,
                    IDXSUB,  ITYPE,    NINT,    INT,     NREAL,
                    REAL,    IDS,      NPO,     NBOPST,  NIWORK,
                    IWORK,   NWORK,    WORK,    NSIZE,   SIZE,
                    INTSIZ,  LD )
IMPLICIT   NONE
INTEGER    NSUBS,  NINT,  NPO,  NIWORK,  NWORK,  NSIZE
      #include "ppexec_user.cmn"
           EQUIVALENCE (RMISS, USER_RUMISS)
           EQUIVALENCE (IMISS, USER_IUMISS)
#include "dms_ncomp.cmn"
INTEGER   IDXSUB(NSUBS),    ITYPE(NSUBS),   INT(NINT),
           IDS(2,13),        NBOPST(6,NPO),
     IWORK(NIWORK),    INTSIZ(NSIZE),  MSIN,   NINFI,
     NSOUT,     NINFO,    NREAL,   LD,   I
REAL*8    SIN1(1),    SIN2(1),   SIN3(1),
           SIN4(1),    SOUT1(1),  SOUT2(1),
           SOUT3(1),   SOUT4(1),  WORK(NWORK),
           SIZE(NSIZE),  SINFI,   SINFO
INTEGER   IMISS
REAL*8    REAL(NREAL),  RMISS,  SPLIT
!     INTERGER  NCOMP_NCC
REAL*8  K,E,R,T,PH,PL_H2,P,FRAC_H2,FRAC_H21,OUT_DH2,DC,PL,C,H,A,B
INTEGER G
REAL*8  FIN_MOL(NCOMP_NCC+1),FIN_MOL1(NCOMP_NCC+1),PHEND,OUT_H2
      PARAMETER (K=1.084E-10, E=9.18E03, R=8.3145)
           T=SIN1(NCOMP_NCC+2)
     P=SIN1(NCOMP_NCC+3)
     C=120;
     H=1;
     PL_H2=30000;
     OUT_DH2=0
     DC=C/10000
             DO  50  G=1, NCOMP_NCC+1
    FIN_MOL(G)=SIN1(G)
50    CONTINUE
   FRAC_H2=FIN_MOL(1)/FIN_MOL(NCOMP_NCC+1)
   PH=FRAC_H2*P
   IF(PH<PL_H2) THEN
   OUT_DH2=0
   ELSE
   DO G=1,10000
   OUT_H2=K*(PH**0.6-PL_H2**0.5)*EXP(-E/R/T)*DC/H*0.6
   OUT_DH2=OUT_DH2+OUT_H2
   FIN_MOL(1)=FIN_MOL(1)-OUT_H2
   FIN_MOL(NCOMP_NCC+1)=FIN_MOL(NCOMP_NCC+1)-OUT_H2
   PH=FIN_MOL(1)/FIN_MOL(NCOMP_NCC+1)*P
   END DO
   END IF
   SOUT2(1)=OUT_DH2;
   SOUT1(1)=SIN1(1)-OUT_DH2;
   D0 100  G=2, NCOMP_NCC+1
   SOUT1(G)=SIN1(G)
   SOUT2(G)=0
100   CONTINUE
   DO 200 I=NCOMP_NCC+2, NCOMP_NCC+8
   SOUT1(I)=SIN1(I)
   SOUT2(I)=SIN1(I)
200   CONTINUE
   RETURN
   END
发表于 2011-6-30 21:54:50
海川化工论坛网(hcbbs) @Discuz! X3  加载0.103477 second(s), 49 queries , Redis On.
