服务2亿工业人 [化海川流] 一键加入
不限速链接
Product:AVEVA PRO/II Simulation
Version:2023.0 (build 18.01.2023)
Supported Architectures:x64
Website Home Page :www.aveva.com
Languages Supported:english
System Requirements:Windows *
AVEVA, a global leader in engineering and industrial software, is pleased to announce the availability of AVEVA PRO/II Simulation (formerly PRO/II) 2023.0. Designed to perform rigorous heat and material balance calculations for a wide range of chemical processes, AVEVA PRO/II Simulation offers a wide variety of thermodynamic models to virtually every industry.​
AVEVA PRO/II Simulation 2023.0 Release Notes - Date: January 2023
AVEVA PRO/II Simulationis a professional simulation tool that offers a comprehensive simulation solution for process design, revamp, and operational analysis. AVEVA PRO/II Simulation performs rigorous mass and energy balances for processes ranging from oil and gas separation to reactive distillation. AVEVA PRO/II Simulation has the power and flexibility to simulate a wide range of processes at steady state, from refining to chemicals. AVEVA PRO/II Simulation provides robust and accurate results based on industry-standard thermodynamic methods and physical property data. AVEVA PRO/II Simulation is a valuable tool allowing engineers and management to enhance the bottom line of their process or plant.
AVEVA PRO/II Simulation - The Industry Leading Steady-State Process Simulator
AVEVA PRO/II Simulation (formerly PRO/II) makes the complex simple. It's used by engineers around the world every day to perform heat and material balance calculations for all types of refining and chemical processes, giving them accurate insight into plant behavior and constraints.
AVEVAis a global leader in engineering and industrial software driving digital transformation across the entire asset and operations life cycle of capital-intensive industries. The company's engineering, planning and operations, asset performance, and monitoring and control solutions deliver proven results to over 16,000 customers across the globe. Its customers are supported by the largest industrial software ecosystem, including 4,200 partners and 5,700 certified developers. AVEVA is headquartered in Ca
mbridge, UK, with over 4,400 employees at 80 locations in over 40 countries.
PROII2023.zip
(286 Bytes, 下载次数: 3, 需虚拟分: 2000财富)
发表于 2023-5-14 19:43:40
