[讨论] 认识工业设备及制品--管道泵
806 |1
防腐之家平台VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP河北省
发表于 2023-2-17 14:43:21
当前内容由会员用户名 防腐之家平台 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
chinatuyuVIP会员 VIP会员 | 显示全部楼层       最后访问IP湖南省
荣誉会员  |  头衔:  【工业技术专业讨论者】
Pipe pumps,也称为转子泵,是用来将液体从一个容器转移到另一个容器的一种常见的工业设备。它们通常由一个电机驱动的转子组成,其中的转子在两个密封的气体室之间转动,以创造出一种真空,用以抽出液体。当转子转动时,它将液体从入口管道中抽入,并将液体推向出口管道中去,从而达到转移液体的目的。管道泵可用于在各种工业应用中转移多种液体,如水,油,燃料等。这种设备非常灵活,可根据客户的需求来配置转速,流量,压力等参数。
Pipe pumps are a common type of industrial equipment used to transfer liquid from one container to another. They usually consist of a rotor driven by an electric motor, which rotates between two sealed chambers of gas to create a vacuum which sucks out the liquid. As the rotor rotates, it draws liquid from an inlet pipe and pushes it out of an outlet pipe, thus transferring the liquid. Pipe pumps can be used to transfer a variety of liquids such as water, oil, and fuel in various industrial applications. They are highly versatile, allowing for the configuration of parameters such as speed, flow rate, and pressure based on customer needs.
发表于 2023-2-21 10:29:20
海川化工论坛网(hcbbs) @Discuz! X3  加载0.531705 second(s), 49 queries , Redis On.
