[求助] aspen edr coil wound 报错
3.3K |1
喝无胡.VIP会员 VIP会员 化海川流M | 显示全部楼层 |阅读模式       最后访问IP江苏省
Currently, the shell side condensation modeling is not available for Coil
Input Error 1533 Wound Heat Exchangers. You may change the shell side stream to a faling film (or boiling) flow in the process data.
壳侧冷流 管侧热流  谢谢大佬
发表于 2022-11-27 21:44:45
当前内容由会员用户名 喝无胡. 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.113010 second(s), 50 queries , Redis On. | 网站统计 |
