[ASPEN] 运算错误
3.7K |1
lezeexVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP浙江省
<< All Blocks Reinitialized >>
<< Run reinitialized 15:53:32 Sun Aug 5, 2018>>
->Processing input specifications ...
  *   WARNING IN THE "STREAM" PARAGRAPH WHICH BEGINS ON LINE 63
      STREAM NAME: AIRIN
      COMPONENT MASS FRACTIONS ARE NORMALIZED TO UNITY.
  Flowsheet Analysis :
Block $OLVER01 (Method: WEGSTEIN) has been defined to converge
         streams: Q3        9
COMPUTATION ORDER FOR THE FLOWSHEET:
$OLVER01 AIRHEAT CH4HEAT H2OHEAT MIXER PREFORM STACK COMB
|  HEATER2
(RETURN $OLVER01)
->Calculations begin ...
> Beginning Convergence Loop $OLVER01 Method: WEGSTEIN
  Converging tear streams: Q3        9
   Block: AIRHEAT  Model: HEATX
  *   WARNING
      AT LEAST ONE FEED HAS ZERO FLOW
      BLOCK BYPASSED
   Block: CH4HEAT  Model: HEATX
  *   WARNING
      BLOCK BYPASSED
   Block: H2OHEAT  Model: HEATX
  *   WARNING
      BLOCK BYPASSED
   Block: MIXER    Model: MIXER
   Block: PREFORM  Model: RGIBBS
   Block: STACK    Model: RGIBBS
   Block: COMB     Model: RSTOIC
  *   WARNING
      COMPONENT "OXYGE-01" HAS ZERO FLOWRATE IN THE OUTLET STREAM.
      FRACTIONAL CONVERSION HAS BEEN MODIFIED BY
      A FACTOR OF "0.3636957E-19"
   Block: HEATER2  Model: HEATER
  *** SEVERE ERROR
      FLASH RESULTS ARE WITHIN TOLERANCE, BUT MAY BE UNSATISFACTORY BECAUSE
      EXTRAPOLATED EOS VAPOR VOLUME ROOT WAS USED FOR PROPERTY CALCULATIONS.
      FAILURE TO SOLVE 2-PHASE ADIABATIC PROBLEM AS TP SUBPROBLEMS. T= 10.0000
      P= 1.0133D+05 HCALC= -6.8411D+07 HFSPEC= -9.3143D+07 PROBLEM OCCURRED
      WHILE FLASHING OUTLET STREAM.
> Loop $OLVER01 Method: WEGSTEIN     Iteration    1
  *** SEVERE ERROR
      P= 1.0133D+05 HCALC= -6.8411D+07 HFSPEC= -9.3143D+07 ERRORS OCCURRED IN
      FLASH CALCULATIONS FOR TEAR STREAM  9 .
   7 vars not converged, Max Err/Tol   0.10000E+07
  **  ERROR
      P= 1.0133D+05 HCALC= -6.8411D+07 HFSPEC= -9.3143D+07 HOT FEED FLASH
      FAILED.
  **  ERROR
      "COLD" STREAM IS HOTTER THAN "HOT" STREAM
      BLOCK BYPASSED
  **  ERROR
      FAILED.
  **  ERROR
      BLOCK BYPASSED
  **  ERROR
      FAILED.
  **  ERROR
      BLOCK BYPASSED
  *   WARNING
      A FACTOR OF "0.3636973E-19"
  *** SEVERE ERROR
> Loop $OLVER01 Method: WEGSTEIN     Iteration    2
# Converged              Max Err/Tol   0.26737E-08
->Generating block results ...
  **  ERROR WHILE GENERATING RESULTS FOR UNIT OPERATIONS BLOCK: "H2OHEAT"
      (MODEL: "HEATX")
      FAILED.
      (MODEL: "HEATX")
      BLOCK BYPASSED
  **  ERROR WHILE GENERATING RESULTS FOR UNIT OPERATIONS BLOCK: "CH4HEAT"
      (MODEL: "HEATX")
      FAILED.
      (MODEL: "HEATX")
      BLOCK BYPASSED
  **  ERROR WHILE GENERATING RESULTS FOR UNIT OPERATIONS BLOCK: "AIRHEAT"
      (MODEL: "HEATX")
      BLOCK BYPASSED
->Simulation calculations completed ...
  ***  Warning(s) were issued during Input Translation ***
  ***  Check the Run Status Results for more Information ***
               ***  Summary of Simulation Errors  ***
                   Physical
                   Property         System        Simulation
  Terminal Errors      0               0               0
    Severe Errors      0               0               3
           Errors      0               0              11
         Warnings      0               0               5
      (MODEL: "HEATX")
      FAILED.
      (MODEL: "HEATX")
      BLOCK BYPASSED
      (MODEL: "HEATX")
      BLOCK BYPASSED
      (MODEL: "HEATX")
      BLOCK BYPASSED
  **  ERROR
      BLOCK BYPASSED
发表于 2018-8-5 15:58:13
955559 + 5 发起议题
当前内容由会员用户名 lezeex 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
lezeex楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
各位老铁看看为啥会这样。
发表于 2018-8-5 15:58:35
海川化工论坛网(hcbbs) @Discuz! X3  加载0.652102 second(s), 48 queries , Redis On. | 网站统计 |  劰载中...
