出现这个问题该如何解决
4K |5
嘉铭VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP广东省
在模拟后,出现下面的问题,该怎么解决?
*   WARNING
      AT Z =   0.19850E-05 :
      REACTION RATE IS GREATER THAN ZERO FOR REACTION (2) BUT
      REACTANT "COS" IS NOT PRESENT.  POSSIBLE CAUSE:
      ZEROTH ORDER REACTANT NOT PRESENT.  RATE IS SET TO ZERO.
  *   WARNING
      AT Z =   0.42778E-05 :
  *   WARNING
      AT Z =   0.63412E-05 :
  *   WARNING
      AT Z =   0.94364E-05 :
  *   WARNING
      AT Z =   0.14079E-04 :
  *   WARNING
      AT Z =   0.21043E-04 :
  *   WARNING
      AT Z =   0.31490E-04 :
  *   WARNING
      AT Z =   0.47159E-04 :
  *   WARNING
      AT Z =   0.70663E-04 :
  *   WARNING
      AT Z =   0.10592E-03 :
  *   WARNING
      AT Z =   0.15880E-03 :
  *   WARNING
      AT Z =   0.23813E-03 :
  *   WARNING
      AT Z =   0.35712E-03 :
  *   WARNING
      AT Z =   0.53561E-03 :
  *   WARNING
      AT Z =   0.80333E-03 :
  *   WARNING
      AT Z =   0.12049E-02 :
  *   WARNING
      AT Z =   0.18073E-02 :
  *   WARNING
      AT Z =   0.27109E-02 :
  *   WARNING
      AT Z =   0.40663E-02 :
  *   WARNING
      AT Z =   0.60993E-02 :
  *   WARNING
      AT Z =   0.91489E-02 :
  *   WARNING
      AT Z =   0.13723E-01 :
  *   WARNING
      AT Z =   0.20585E-01 :
  *   WARNING
      AT Z =   0.30877E-01 :
  *   WARNING
      AT Z =   0.46316E-01 :
  *   WARNING
      AT Z =   0.69473E-01 :
  *   WARNING
      AT Z =   0.10421     :
  *   WARNING
      AT Z =   0.15632     :
  *   WARNING
      AT Z =   0.23447     :
  *   WARNING
      AT Z =   0.35171     :
  *   WARNING
      AT Z =   0.52756     :
  *   WARNING
      AT Z =   0.79134     :
  *   WARNING
      AT Z =    1.1870     :
  *   WARNING
      AT Z =    1.7805     :
  *   WARNING
      AT Z =    2.6708     :
  *   WARNING
      AT Z =    4.0062     :
  *   WARNING
      AT Z =    6.0093     :
  *   WARNING
      AT Z =    9.0139     :
   Block: COOLER2  Model: HEATER
   Block: SEP2     Model: FLASH2
   Block: REBOIL2  Model: HEATER
   Block: CLAUS2   Model: RPLUG
  *   WARNING
      AT Z =   0.87000E-01 :
  *   WARNING
      AT Z =   0.95700     :
  *   WARNING
      AT Z =    9.6570     :
   Block: COOLER3  Model: HEATER
   Block: SEP3     Model: FLASH2
   Block: MIXER    Model: MIXER
->Generating block results ...
    Block: COOLER1  Model: HEATER
    Block: REBOIL1  Model: HEATER
->Simulation calculations completed ...
  ***  No Warnings were issued during Input Translation ***
               ***  Summary of Simulation Errors  ***
                   Physical
                   Property         System        Simulation
  Terminal Errors      0               0               0
    Severe Errors      0               0               0
           Errors      0               0               0
         Warnings      0               0              41
发表于 2017-5-12 22:30:31
zhxbkofkyo + 3 发起议题
当前内容由会员用户名 嘉铭 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
木易之斤1VIP会员 VIP会员 | 显示全部楼层       最后访问IP安徽省
我也遇到了,一直没解决,好像是动力学参数的问题
发表于 2017-5-24 22:10:06
我也遇到了,好像是动力学的问题,一直没解决。
发表于 2017-5-24 22:10:58
zhxbkofkyoVIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
海川工程师(荣誉)  |  头衔:  【海川资深技术人员】
看警告是说你反应器还没走完,其中一个反应物已经消耗完了,应该是动力学参数有问题了吧,看看单位有没有问题?
发表于 2017-5-25 08:50:28
嗯,是动力学参数的问题,谢谢了  发表于 2017-5-31 17:22
一笔丹青VIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
zhxbkofkyo 发表于 2017-5-25 08:50
看警告是说你反应器还没走完,其中一个反应物已经消耗完了,应该是动力学参数有问题了吧,看看单位有没有问 ...
您好 我想问一下  还有其他的解决办法吗?
发表于 2020-3-17 21:47:56
海川化工论坛网(hcbbs) @Discuz! X3  加载0.210506 second(s), 70 queries , Redis On. | 网站统计 |
