[工具软件] FIRST CONVAL11.3/11.5 来自德国的老牌阀门计算软件
33.1K |150
Description
FIRST CONVAL functionality calculate wide for the components and processes in engineering systems, and industrial, based on the methods tested, such as DIN, VDI, etc. VDMA EN / ISO and ISA integrates. CONVAL by avoiding all types of dependence on equipment manufacturers and … professional work and flexibility guarantees. The range of calculations available, from control valves and elements of the valve through piping systems to heat exchangers, including the calculation of properties of complex (based on a database) and base comprehensive for valves, control, safety valves, etc. materials, etc as the standard spreads.
Features and software the FIRST CONVAL :
Compute the amount, CV, etc. the total flow or high and low pressure
The calculation method is improved according to the length of the outlet cylindrical
Calculate the energy balance (power loss) and the level of sound pressure
Calculate the inner diameter, the pressure, differential., the volumetric flow and the flow Jeremy
Calculate the differential pressure and output signal in the transmitter for each level
Calculate stress improved (ASME 31 in. 3 / AD 2000 / ISO 5167, etc.)
Calculate the uncertainty level, the relative dependence of the density (for example, to check the influence of ambient temperature, with tanks, with two liquids)
The calculation for the system of a single tube with a valve control as a function of the closing time, and features the valve is characterized by
Calculate the flow features installed with optimized graphics – including the impact of receiver upload, edit, and viscosity structures of the resistance down
Performance index key “Ri” (indicator reliability) or (Reliability index). This database is a system expert with alarms, etc., warnings and detailed hints to improve the overall reliability for applications in liquid, gas and steam.
CONVAL® 11 - THE instrumentation, automation & process engineering
software for engineers, planners and operators of industrial process plants.
CONVAL® offers extensive calculation options for components and processes in the process industry. Proven procedures according to DIN, VDI, VDMA EN/ISO standards or ISA, ASME, API, etc. are used as a basis. This ensures that the right calculation basis is always available, even in international projects.
CONVAL® guarantees flexible and professional use through absolute independence from device manufacturers, without having to forego specific manufacturer data.
The range of calculations offered extends from control valves, throttle devices, thermometer protection tubes / thermowells, piping calculations to heat exchangers or pumps. Integrated property data calculation (property database, thermodynamics) and extensive databases for actuators, safety valves, flowmeters, media, materials etc. are part of the software package.
CONVAL® thus covers process engineering requirements such as instrumentation in FEED projects as well as basic & detail engineering, maintenance or plant expansion.
登录/注册后可看大图
游客,如果您要查看本帖隐藏内容请回复
发表于 2023-6-10 07:43:51
spirit_hghc + 2 可惜没有123盘
当前内容由会员用户名 speedhorse09 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
shijiaVIP会员 VIP会员 | 显示全部楼层       最后访问IP河北省
谢谢分享,学习一下。
发表于 2023-6-10 09:39:15
long429lVIP会员 永久VIP | 显示全部楼层       最后访问IP上海市
学习学习
发表于 2023-6-10 15:08:56
pklwz0608VIP会员 VIP会员 | 显示全部楼层       最后访问IP四川省
发表于 2023-6-10 22:01:20
JH.Chen | 显示全部楼层       最后访问IP广西壮族自治区
海川小学2年  |  头衔:  【工艺工程师】
能用不?
发表于 2023-6-10 23:51:50
javen2422VIP会员 VIP会员 | 显示全部楼层       最后访问IP台湾省
Thanks!
发表于 2023-6-11 09:55:17
四海有闲田VIP会员 VIP会员 | 显示全部楼层       最后访问IP法国
已绑手机   ★悬赏任务→ 发悬赏(0)  承接(2/2)
学习学习
发表于 2023-6-11 10:41:08
发表于 2023-6-11 13:17:19
zhxbkofkyoVIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
海川工程师(荣誉)  |  头衔:  【海川资深技术人员】
好东西,看一看
发表于 2023-6-12 08:29:28
wxe2008 | 显示全部楼层       最后访问IP河北省
谢谢分享,学习一下。
发表于 2023-6-12 13:09:44
生如夏花_Qg44qVIP会员 VIP会员 | 显示全部楼层       最后访问IP山东省
学习学习
发表于 2023-6-12 13:58:45
非常好的资料,谢谢分享
发表于 2023-6-12 13:59:09
谢谢分享谢谢
发表于 2023-6-12 18:18:09
江河123VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
看下是否有用
发表于 2023-6-13 08:20:43
xjuingVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
非常感谢楼主的分享
发表于 2023-6-21 20:32:01
dugufengVIP会员 永久VIP | 显示全部楼层       最后访问IP四川省
谢谢楼主分享
发表于 2023-6-23 08:42:38
楚天湘水VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
学习一下
发表于 2023-6-24 22:59:40
学习,学习,再学习。
发表于 2023-6-25 07:48:20
出奇不逸VIP会员 永久VIP | 显示全部楼层       最后访问IP巴西
感谢分享,学习一下
发表于 2023-6-25 16:21:41
资料不错,可以学习
发表于 2023-6-26 08:49:50
海川化工论坛网(hcbbs) @Discuz! X3  加载0.394352 second(s), 158 queries , Redis On.
