海奥膜
[原创] 640C0024G01数字输入输出板 Digital Board 工业制冷配件合计
8.3K |0
kuaianjiaVIP会员 永久VIP | 显示全部楼层 |阅读模式       最后访问IP山东省
  终身会员:HC8101196  已绑手机   ★悬赏任务→ 发悬赏(0)  承接(0/0)
Frick Number        SAP Number        Description
640C0057G01        484532        Analog Board #1 (Replaces e*sting 32 channel board #1 only - no hardware)
640C0057G02        484533        Analog Board #2 (Replaces e*sting 32 channel board #2 only – no hardware)
640C0057G11        484534        Analog Board #1 (Field Upgrade Kit – Includes 32 ch. board #1, connectors & hardware.)
640C0057G12        484535        Analog Board #2 (Field Upgrade Kit – Includes 32 ch. board #2, connectors & hardware.)
649A1027G14        643440        2-Pole connector (P8 – Analog Board)
649A1027G11        485874        Connector kit for Input Ch. 1-16 (Analog Board)
649A1027G21        643460        Connector kit for Input Ch. 17-24, and Output Ch. 1-8 (Analog Board)
649A1027G31        643461        Connector for Power/Communications for Analog Board
640C0024G01        484494        Digital Board #1 (Replaces e*sting board only - no hardware)
640C0024G02        484495        Digital Board #2 (Replaces e*sting board only - no hardware)
649D5948G01        826167        Digital Board #2 (Field Upgrade Kit– adds a second digital board)
639D0203H01        N/A        AC harness for Digital board # 1
639D0203H02        N/A        AC harness for Digital board # 2
639D0191H03        696516        Harness Kit, Q5 to Interface Board Interconnect
333Q0001786        N/A        Battery, 3V (located on Q5 board)
639B0116H01        677556        Interface Board (Does not include interconnect harness kit)
640C0024S01        N/A        Digital I/O Board
640C0057S01        484537        Analog I/O Board (32 Channel)
640C0057G11        484534        Analog Board #1 (Field Upgrade Kit – Includes 32 channel board #1, connectors & hardware.)
640C0057G12        484535        Analog Board #2 (Field Upgrade Kit – Includes 32 channel board #2, connectors & hardware.)
649B0903H01        486156        2-Pole connector (P8 – Analog Board)
333Q0001258        467049        6-Pole connector (P1 through P6 – Digital Board, P4A through P10B – Analog Board)
333Q0001234        467040        8-Pole connector (P11A and P11B – Analog Board)
649B0903H02        486157        9-Pole connector (P2 – Analog Board)
649D5210G21        660132        Digital Board #2 (Field Upgrade Kit– adds a second digital board for 22 x 18 x 10 panels)
639A0278H01        548266        Display Adapter Board (Bat Wing for Q5)
639D0195H01        694590        Harness, AC for Digital Board # 1, Q5
639D0195H02        809832        Harness, AC for Digital Board # 2, Q5
639D0191H01        677557        Harness Kit, Interface to Q5 board.
                Q5 Boards
649C1152G01        813400        Q5 CPU Board Replacement (Q5 to Q5 Replacement Kit)
639B0116G01        809831        Interface Board Q5 LX Field Replacement Kit w/screws
                Q5 Boards
649D5210G11        486364        Digital Board #2 (Field Upgrade Kit– adds a second digital board for 22 x 18 x 10 panels)
649D5070H01        486299        AC harness for Digital Board #1 (22 x 18 x 10 panel)
649D5070H02        486300        AC Harness for Digital Board #2 (22 x 18 x 10 panel)
333Q0001786        N/A        Battery, 3V (located on Q3, and 4 board)
639C0130G01        484378        Communications Daughter board only for Quantum 4.
640C0062G01        1107799        Analog Board #1 (Replaces e*sting “614” analog board only - no hardware)
640C0062G02        1107800        Analog Board #2 (Replaces e*sting “614” analog board only - no hardware)
640C0062G11        1108061        Analog Board #1 Field Upgrade Kit (Requires LX software version 7.11 or later and 24 VDC)
640C0062G12        1108062        Analog Board #2 Field Upgrade Kit (Requires LX software version 7.11 or later and 24 VDC)
(1) Note: If replacing an older style analog board, contact Frick Service for details.
649A1027G01        485871        6-Pole connectors (P1 through P6 – Digital Board 1)
649A1027G02        485872        6-Pole connectors (P1 through P6 – Digital Board 2)
649A1027G11        485874        6-Pole connectors (P4A through P7B – Analog Board 1 & 2)
649A1027G21        643460        6-Pole and 8-Pole connectors (P9A and P11B – Analog Board 1 & 2)
9-Pole connector (P2 – Analog Board 1 & 2, for vertically mounted boards with this connec-
639A0278H01        548266        Display Adapter Board (Bat Wing board)
639D0230G01 *        865280 *        LVDS to VGA Converter (Bat Wing board)
639D0230G11 *        865281 *        LVDS to VGA Converter (Bat Wing board)
639D0191H02        696514        Harness Kit, Interface to Q5 board.
640C0062G11        1108061        Analog Board #1 Field Upgrade Kit (Requires HD software version 10.16 or later and 24 VDC)
640C0062G12        1108062        Analog Board #2 Field Upgrade Kit (Requires HD software version 10.16 or later and 24 VDC)
649A1027G14        643440        2- Pole connector (P8 - Analog Board)
                Digital Boards
649D5948G01        826167        Digital Board #2 (Field Upgrade Kit- adds a second digital board)
639D0203H01        716615        AC harness for digital board # 1
639D0203H02        716616        AC harness for digital board # 2
333Q0001786        886046        Battery, 3V (located on Q5 board)
                Q5 Board
                Q6 Board
                Digital Boards
640C0024G01        484494        Digital Board #1 (Replaces™        e*sting board only - no hardware)
Page640C0024G02 122        484495        Digital Board #2 (Replaces e*stingMAINTENANCE board only - no hardware)
                Q5 Board
                Q6 Board
发表于 2022-1-11 11:00:23
【提示:直接搜索3290680可直达本帖。】
当前内容由会员用户名 kuaianjia 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.056047 second(s), 32 queries Redis On.
