[讨论] MTBE反应精馏模拟.在添加副反应后,精馏塔出错
2.3K |1
LCXIAOWEIVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP甘肃省
使用版本为Aspen Plus9.0
** ERROR
   OUTSIDE LOOP TOLERANCE WAS SATISFIED BUT DESIGN SPEC ITERATION
   (MIDDLE LOOP) FAILED TO CONVERGE.
***SEVERE ERROR
   MATERIAL AND ENERGY BALANCES FAILED TO CONVERGE: CHECK COL-SPECS
   OR SUPPLY BETTER TEMPERATURE AND COMPOSITION ESTIMATES.
** ERROR
   BLOCK B1 IS NOT IN MASS BALANCE:
   MASS INLET FLOW = 0.47944444E+01, MASS OUTLET FLOW = 0.68096626E+01
   RELATIVE DIFFERENCE = 0.42032361E+00
The following messages were issued during Report Generation:
*  WARNING
   KEY COMPONENT SPECIFICATIONS ARE OR BECOME INCONSISTENT
   ON THE FOLLOWING STAGES:
   14   15   16   18   20   21   25
   COLUMN TARGETING THERMAL ANALYSIS IS SKIPPED.
发表于 2019-5-8 21:03:26
40kta的MTBE.rar
630.23 KB, 下载次数: 0, 下载积分:财富 -10 财富值
【提示:直接搜索2696300可直达本帖。】
当前内容由会员用户名 LCXIAOWEI 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
建议调整下操作变量
发表于 2019-5-14 17:42:16
海川化工论坛网(hcbbs) @Discuz! X3  加载0.119275 second(s), 43 queries Redis On.
