[求助] flange coupling是神马东西?
1.3K |5
WW88_8VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP科威特
如题,求指教
发表于 2017-5-12 09:53:12
夏,微凉 + 5 发起议题
当前内容由会员用户名 WW88_8 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
凸缘联轴器
发表于 2017-5-12 10:28:52
jujiangliuVIP会员 VIP会员 | 显示全部楼层       最后访问IPInvalid
法兰连接。
发表于 2017-5-12 10:29:14
德国阻火器VIP会员 VIP会员 | 显示全部楼层       最后访问IP辽宁省
A flange coupling is a type of coupling device meant to bring two tube ends together in a flush, sealed manner. This two-piece coupling unit consists of a keyed receiving side for the flanged end to be fastened to, so it may be married to the opposing tube end, which also has a flanged end. Each flange has either a male or female coupler opening so that when the two ends are brought together, they are aligned without causing resistance or drag in the material being passed through them. This male/female coupling method also creates a stable connection that is resistant to shifting, keeping the flange coupling sturdily in place.
供参考:http://www.wisegeek.com/what-is-a-flange-coupling.htm
就是法兰连接
发表于 2017-5-12 11:58:58
shzmzkVIP会员 VIP会员 | 显示全部楼层       最后访问IP上海市
法兰连接,楼上解释的很清楚的呢
发表于 2017-5-12 15:40:26
黉山坡下 + 3 积极参与
法兰(flange)连接(coupling)
发表于 2017-5-13 11:29:17
黉山坡下 + 3 积极参与
    海川化工论坛网(hcbbs) @Discuz! X3  加载0.077448 second(s), 79 queries , Redis On.
