[石油化工] 环戊烷
19.5K |0
零落浮华VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP辽宁省
简介
% C# u- X& r$ V! S, P8 l) P# ~6 D环戊烷,是一种无色流动性易燃液体,有苯样的气味;不溶于水溶于醇、醚、苯、四氯化碳、丙同等多数有机溶剂;相对密度(水=1)0.75;相对密度(空气=1)2.42,性质稳定; ;主要用作溶剂和色谱分析的标准物质。* T8 S# t, ?4 v2 t* `! S+ I2 r
中文名:环戊烷
9 a& D9 w5 w8 p, m4 n+ b外文名:Cyclopentane* [8 B/ ?7 F8 i- a: V& |
化学式:C5H10;(CH2)51 k6 V+ ?+ _; p% u# r/ e) y
分子量:70.13# u- Z+ m1 P: J( U; R$ D
CAS登录号:287-92-3
5 T; s& o9 {& P/ TEINECS登录号:206-016-6
" G2 w7 V  [9 r/ Q* x熔    点:-94.14 ℃, Y( ^9 U8 w1 z$ v# ]3 [
沸    点:49.3 ℃; t7 W1 F9 h: [) L
水溶性:不溶于水. c) y( k7 F0 h4 {% K" Y) O& {/ z
密    度:相对密度(水=1)0.75
  R2 F" H: E5 C/ Y: T闪    点:-37 ℃/ ]" x6 e, s5 A( _
物理性质
2 z# ^0 s2 q; r7 U熔点:-94.14℃; [: `; _, q. G6 k# s2 \# O& w
沸点:49.3℃
; E0 A% B" Y* _, g' C+ ^闪点: -37℃
$ j: d# I/ `) f- H, u折射率: n20 D1.4068* }9 M6 w! K7 \; L1 L  o$ _
蒸汽压: 45(20℃)
9 D3 _6 E8 m" E溶解性: 不溶于水,溶于乙醇、乙醚、苯、四氯化碳、丙同等多数有机溶剂
9 c7 [: f$ R2 T临界温度: 238.6
1 Y( ?. B; I0 g临界压力: 4.528 S5 P' y0 k4 t3 Y+ O
自燃温度: 682℉/361 ℃/634K.5 X: y: t4 {: |1 s
爆炸上限: 8.7! ~) K' g& n" t
爆炸下限: 1.1
+ z: T! Y$ n$ }" v' a9 J& [: R% C相对蒸汽密度: 2.429 _7 a% j& f- N0 k1 O
汽化热比: 1.1217
# m5 f, \3 u& [' R4 M1 A3 f潜汽化热: 170 Btu/lb = 94 cal/g = 3.9 x 105 J/kg.
  I# U5 A' t8 T' `( I燃烧热: 3287.8 kJ/mol
; W* {6 ]2 i  [% K表面张力: 23 dynes/cm = 0.023 N/m at68℉/20℃.
, c7 B) E( w& M& T2 o; b0 gLogP: 3.0/ a  |+ J; b$ x. G& ]& J# m( V
相关类别: Pharmaceutical Intermediates;Organics;Organic Chemicals;有机化学品;Alpha Sort;C;CAlphabetic;Chemical Class;CO - CZChemical Class;Hydrocarbons;NeatsAnalytical Standards;Volatiles/ Semivolatiles;Solvents - HPLC;Analytical Reagents;Chromatography/CE Reagents;Anhydrous Grade SolventsSolvents;Solvent Bottles;Solvents;Sure/Seal? Bottles;ReagentPlus(R) Solvent Grade Products;ReagentPlus(R)Solvents;Reagent Grade Solvents;ReagentSolvents;Amber Glass Bottles;CHROMASOLV for HPLCSolvents;CHROMASOLV Solvents (HPLC, LC-MS);CHROMASOLV(R) HPLC Grade Solvents;烷;ACS and Reagent Grade Solvents;Amber Glass Bottles;ReagentPlus;ReagentPlus Solvent Grade Products;Solvent Bottles;Solvent by Application;Solvent Packaging Options;Analytical Reagents;Analytical/Chromatography;CHROMASOLV for HPLC;Chromatography Reagents &;HPLC &;HPLC Grade Solvents (CHROMASOLV);HPLC/UHPLC Solvents (CHROMASOLV);UHPLC Solvents (CHROMASOLV);脂肪烃;分析标准品;通用试剂;脂肪烃类;超干溶剂;溶剂;有机硅化合物
+ ~1 D* m' ?4 y5 ]Mol文件: 287-92-3.mol  _4 q8 u% |( F+ d) L
类别! T" {% D! m+ }! x, Z& p
易燃液体
. ~) ]: E% V% K毒性分级 低毒5 z1 I7 [- C( z$ l+ T
急性毒性 口服-大鼠 LD50: 11400 毫克/公斤; 口服-小鼠 LD50: 12800 毫克/公斤7 {4 m8 N0 ^8 T. H" T9 e  C
**危险特性 与空气混合可爆' X% j9 y7 |" f! T
可燃性危险特性 遇明火、高温、氧化剂易燃; 燃烧产生刺激烟雾8 J6 n$ z4 ?) Z' O
储运特性 库房通风低温干燥; 与氧化剂分开存放
3 ?+ p- s7 D2 S灭火剂 干粉、二氧化碳、泡沫、1211灭火剂
5 |9 |: n/ S8 W8 [( P/ B职业标准 TWA 1720 毫克/ 立方米; STEL 2150 毫克/公斤3 {3 P  ^0 h1 W& O6 P6 m# n% j: A
有害影响- v& z% p. v* C/ S
吸入高浓度环戊烷可引起中枢神经系统抑制,尽管其急性毒性低。急性暴露引起的症状先有兴奋,以后出现平衡失调,乃至木僵、昏迷。很少因呼吸衰竭而死亡。有人报道过,给动物口饲本品,出现严重腹泻,导致心、肺和肝血管萎陷及脑变性。
: d" r+ l- c+ E防护措施
9 I' E; @) W8 O' N$ Y5 }/ r改善生产设备。用皮肤防护药膏或戴手套来保护皮肤。
4 ~% f8 i5 g3 K- r医学监护7 E( [6 ~7 U9 P; X) \
定期体检时,注意皮肤和呼吸道的可能刺激作用以及肾和肝的任何并发症。  |5 ]- O: `6 T/ K7 x: P! T7 u6 u- s
运输要求
4 i: j7 G) u8 _& u* `: H一级易燃液体。危规号; 61013。运输时容器上须标有“易燃液体”标记。/ m' p+ j8 T+ I/ Y5 F
处理方法5 s4 S1 `  U' Z' I% P) u
焚烧。
* ?4 D; j7 |/ L0 _; M
8 c  s# ^: _5 o
主要用途
0 ?0 v/ j2 X( t0 a- b/ e9 C用来替代氟里昂广泛用于电冰箱、冰柜的保温材料及其他硬质PU泡沫的发泡剂;用作聚异戊二烯橡胶等溶液聚合用溶剂和纤维素醚的溶剂及色谱分析标准物质。
" n* i+ d+ j- ~2 @5 {
生产技术
5 ?7 A( d& G6 k2 [
! g$ v9 W& O" f% Z
* j1 @5 c4 m1 L7 W. a# d% S
安全防护
, I, F+ p/ N/ k, P; D2 x: K该物质对环境有危害,应特别注意对地表水、土壤、大气和饮用水的污染,在环境中能被生物降解。
, s& B7 }* O) [健康危害
5 \! M8 \7 h  i/ @侵入途径:吸入、食入、经皮吸收。1 R6 ^# ]' O9 g* t3 P+ ~6 \+ X
健康危害:吸入后可引起头痛、头晕、定向力障碍、兴奋、倦睡、、共济失调和麻醉作用。呼吸系统和心脏可受到影响。对眼有轻度刺激作用。口服致中枢神经系统抑制、粘膜出血和腹泻。' z7 o1 ~- C! X# L
毒理学资料及环境行为5 W  I1 f4 p/ ]
毒性:属低毒类。有刺激和麻醉作用。1 G5 o2 L0 t$ v% Z
急性毒性:LC38000ppm×2小时(小鼠吸入)
4 n; i% E, K; b, y, T( q危险特性:极易燃,其蒸气与空气可形成爆炸性混合物。遇明火、高热极易燃烧爆炸。与氧化剂接触发生强 烈反应,甚至引起燃烧。在火场中,受热的容器有爆炸危险。其蒸气比空气重,能在较低处扩散到相当远的地方,遇明火会引着回燃。
  H1 `! U+ j. ^$ j( @" b燃烧(分解)产物:一氧化碳、二氧化碳。& u, t0 N6 {* _% n' a
- m, @( `. R1 Q8 N1 J- J1 J应急处理
5 s% w4 t8 A+ V- ~3 W一、泄漏应急处理
$ `: k0 ]' _  F2 u$ z迅速撤离泄漏污染区人员至安全区,并进行隔离,严格限制出入。切断火源。建议应急处理人员戴自给正压式呼吸器,穿消防防护服。尽可能切断泄漏源。防止进入下水道、排洪沟等限制性空间。小量泄漏:用活性炭或其它惰性材料吸收。也可以用不燃性分散剂制成的乳液刷洗,洗液稀释后放入废水系统。大量泄漏:构筑围堤或挖坑收容;用泡沫覆盖,降低蒸气灾害。用防爆泵转移至槽车或专用收集器内,回收或运至废物处理场所处置。3 v* ?( a& C5 y5 a+ h
二、防护措施* W4 M, I9 X3 U9 N3 m' s, f( F
呼吸系统防护:空气中浓度超标时,佩戴自吸过滤式防毒面具(半面罩)。: M2 ^4 K( c" \( i* j
眼睛防护:一般不需要特殊防护,高浓度接触时可戴化学安全防护眼镜。' I6 v3 p8 ?0 O8 R
身体防护:穿防静电工作服。9 |& F; h& I4 J% T$ Z! |: K
手防护:戴防苯耐油手套。
- _& c; n/ y1 D# _$ M其它:工作现场严禁吸烟。避免长期反复接触。
# j1 I3 x, C8 a( N! Z2 C0 P0 e% h三、急救措施
& ^/ o0 n/ q' c4 M9 y$ M% ]6 }皮肤接触:脱去被污染的衣着,用肥皂水和清水彻底冲洗皮肤。0 ]8 x( H0 ^& @
眼睛接触:提起眼睑,用流动清水或生理盐水冲洗。就医。7 u6 P' w5 x1 r5 g9 _
吸入:迅速脱离现场至空气新鲜处。保持呼吸道通畅。如呼吸困难,给输氧。如呼吸停止,立即进行人工呼吸。就医。6 U" H) V( U; ?5 b+ [
食入:饮足量温水,催吐,就医。( `/ F4 j% p- Y9 H$ |" ^! Y$ \
灭火方法:喷水冷却容器,可能的话将容器从火场移至空旷处。处在火场中的容器若已变色或从安全泄压装置中产生声音,必须马上撤离。
8 a+ y- P0 [: J) Y% ^灭火剂:泡沫、干粉、二氧化碳、砂土。用水灭火无效。& p( Q& u* X, F0 p4 N$ m' h
' p% U  Y( H& \, I# F
待增加
, k# D) [0 M$ \
/ I. q( K* h- q- D
相关资料
7 }/ x0 l9 s# a; C5 D2 N
安全信息
/ Z$ ?0 T/ T2 f" T危险品标志 F: ^# t4 V# D6 F7 i  A  J1 |
危险类别码 11-52/53; f- {, R1 x$ u8 }3 J3 C: r
安全说明 9-16-29-33-61( G1 E. _2 D. V% X4 c9 @
危险品运输编号 UN 1146 3/PG 2# g2 ~- d0 R. N. o
WGK Germany 1
8 ?1 w( v2 I+ \& a: E( l( PRTECS号 GY2390000
! L0 x' j& Q$ B& j# eHazardClass 30 Q: Y1 W0 C' x' `
PackingGroup II5 ?" L4 ~( ?8 B+ _6 d
毒害物质数据 287-92-3(Hazardous Substances Data)5 v5 K" B- z' D, w3 Y
储运方法* T0 Z3 a: n; B
库房通风低温干燥; 与氧化剂分开存放" b( N' N" r) e7 [" {* q* f
危险品运输编号 UN 11463 Z) O3 j) W1 d2 t. }
安全术语
8 u5 h$ _/ L( @; u5 j& TS9Keep container in a well-ventilated place. 保持容器置于良好通风处。
3 C  i3 j2 \9 o8 D7 |* SS16Keep away from sources of ignition. 远离火源。
* c; F" l" ]& X( \8 c3 i( RS29Do not empty into drains. 切勿倒入下水道。$ c) `' {. D: y8 f! T* a
S33Take precautionary measures against static discharges. 采取措施,预防静电发生。
7 V+ R1 @% `8 ^7 c6 u% ~/ v: J$ BS61Avoid release to the environment. Refer to special instructions / safety data sheets. 避免释放至环境中。参考特别说明/安全数据说明书。 [1]
7 L, k5 z- L- ~6 M' ^6 v风险术语$ m' _% v. p' D  p3 ]$ m2 r0 D8 U  E
R11Highly flammable. 高度易燃。( o  E0 T# Z* o; Z7 p: m/ E
R52/53Harmful to aquatic organisms, may cause long-term adverse effects in the aquatic environment. 对水生生物有害,可能对水体环境产生长期不良影响。 [1]
, Q5 d0 q" u5 t
补充内容
( u, e; a, r$ g$ v: n
化学反应编辑, N/ ^# K; z& }" [8 `2 d
环戊烷参与的反应
6 ]7 q5 r" L- s! j: R7 {! u
反应物
5 ~- V+ @& t! X/ p
生成物" J- l8 b$ ]! E1 R# y
反应条件
1 s, z; P; L% T
参考文献
6 Q$ b! W% G; f! h( \: D0 K/ A
diazoacetic acid ethyl este
2 W( d( u! ?5 F  f& J$ Jcyclopentan
5 m/ V2 Q% ~9 N; }
cyclopentyl-acetic acid ethyl este
8 K4 v2 Q6 n# z: O2 n
反应条件15 V. x" S* {) I3 h& O
试剂 CuI! r/ e, n& H' @# h9 ?, Y
hydrotris(3-mesityl)pyrazolylborate thallium salt
* P# N) b# p8 _# r* A, i* G溶剂 CH2Cl24 @* p8 E- H7 {% J0 J" M! k
产率 50 %
4 d# P9 O. f* Q反应条件2+ G: e+ t9 t8 W( Y2 Q. ^; T" z
其他条件 Irradiation8 h. k8 B5 v5 M  \& W& q
[2-3]
& `6 ~0 J$ I& Q: n, Y* \
cyclopentan# O- G4 v9 s1 W: S1 d% L' `
chlorocyclopentan' c: r5 `$ `* i4 g4 N
反应条件1
4 A& Z1 I/ [+ G试剂 chlorine8 U5 }5 o8 D3 Y8 G+ Z$ v% ^
反应温度 <115 ℃4 L- u  D( b# B, w  j
反应条件2
* U& m# X% P$ ^3 O+ K! \" l5 x试剂 chlorine
" }' U8 @+ O) V8 z" w( `. Ftetraethyl lead+ F# z+ X0 \; p5 R' o
反应温度 155 ℃+ n. N$ W% H% W0 {5 \5 Q" S! D' n
反应条件3
$ z) D8 V7 Q1 a5 V( T8 u$ E) M$ \试剂 , CCl4
. N) R" e& o' J) w- a, w% D+ Q产率 13 %
0 C4 e1 i- N. d% ?1 k反应条件4: d% t5 o4 X/ |0 K/ M
试剂 methylene chloride, SbF5& m  F& G$ Y) k! W; X2 c% R9 O) B
产率 74 %
, [) {: S+ ^  N( n3 v- {, U0 T其他条件 1.) -78 ℃, 2 h, 2.) RT, 24 h+ d( A* c2 \5 l( a* B3 G1 b
[4-8]
) l" Q9 }; M0 `9 {; r4 b! F
cyclopentan' y; |0 z) z0 a, \3 k/ h6 {
cyclopentyl-phosphonic acid-dichlorid' D" X) F* r0 W  C3 m7 K  S' m
反应条件1
8 U/ X1 b: h' M8 [试剂 oxygen& I1 Y: J8 Z0 z  ]+ e* z, a
PCl3+ u( [6 T- i9 u! J6 h+ f$ W: {
反应条件2
, z7 ^9 a* u' l0 W' k. L试剂 AlCl3, PCl3
. Q8 w0 _5 V4 J. d, Y' K溶剂 CH2Cl2
1 f( y, e) \$ s" v' v" C! p反应时间 22 hour(s): g0 @9 G! F% V0 t
产率 18 %
7 z, [1 b7 O5 F% k其他条件 Heating3 O, k3 O) R: r$ s9 K: z
[9-10] + u# x: W7 s- N+ T
cyclopentan
: z, X9 @) X4 A3 A/ L$ D
nitro-cyclopentan) l& q% F& f+ j: |$ c* n- a) z
反应条件1
( r5 }4 S9 n2 z8 A7 M试剂 nitric acid9 j0 C" f5 Y% V+ y
air
7 {9 E* ~  I0 R' V" Z0 f: Z5 v  xN-hydroxyphthalimide
  }9 e( P, d5 ?5 E溶剂 various solvent(s)
# l$ o) R$ g7 l5 }: _5 v* K2 e6 f反应时间 14 hour(s)
: I  }' M+ g" N7 V; K1 u反应温度 70 ℃
& m9 y2 y' A7 V. U$ b* z反应压强 760
2 _3 T  ]- Z( k% Y, z7 `产率 70 %
; J5 a; \% p% d0 @( V$ f* C0 A2 d反应条件2
: z- o7 I9 @) f1 ~  U! v试剂 aluminium nitrate
, Z# h7 @; _; l# u7 @# k. {反应温度 110 - 115 ℃6 A0 V: I+ ?' ?
[11-12]
- W  M! j( s3 y7 ^% C" ~* i: ?
cyclopentan" v4 J9 ]; ]/ n3 P4 P8 M! Z
pentan
7 a- B% {% N- u$ ~0 P$ X
反应条件1. G% r- P: U& }0 i) b6 p
试剂 platinum coal: K) s1 }) m( b3 v0 e
反应温度 300 ℃
+ V7 E0 U6 }2 S% r9 O! o其他条件 Hydrogenation! A! K( U9 H+ p! o  N5 z
反应条件2$ _: t. N( a# i2 f) `7 \
试剂 platinum coal( @+ ]; B5 B8 F$ ], h
反应温度 225 ℃
" u( d( u; Z0 Y! {其他条件 Hydrogenation% q6 r; P- }" o9 ?& I
反应条件34 P! v: G; P  M
试剂 H2
) T: H, E+ B! C. O2 t1 Z: b9 Y6 r0 V催化剂 OsO4
" m3 B2 I, f" Q5 P8 u3 P5 s反应时间 15 hour(s)
3 Y$ V2 a% C' I% ^+ X反应温度 120 ℃/ [" o/ ~5 a# M2 }
反应压强 37503$ z3 @( o1 U5 t4 W) S$ x
产率 90 %7 C8 a# q  W+ I2 U/ U3 k( d. u
其他条件 or 100 to 180 ℃, different Os-catalysts and -concentrations- _' P7 b, \/ ], S+ q# ~
反应条件4
" `' U0 v( l) O8 B+ g6 e5 e9 L试剂 H24 Z: o* f( N2 m% e
催化剂 Pt/AlO3% ]9 Z, z' H) k/ |8 u
反应温度 260 - 350 ℃
: o, E) y+ I# d6 ~7 I! s. Z* D研究目的 Rate constant( n2 {" ~( U1 I2 p2 H" C
其他条件 variation of composition of catalysts
+ a+ z5 a& @$ p- J反应条件5
9 A) L$ r  j9 f# _) x. k# I2 P试剂 Re2(CO)10, AlEt3, H2" S% R$ i- y0 e. o, T0 I  X
反应时间 15 hour(s)3 T& H* m3 G( F! e1 H/ l
反应温度 150 - 180 ℃
4 D6 W( ?/ l- }! [' G$ D, [反应压强 38000
; A, k3 a  ^' w/ H% v+ b研究目的 Product distribution5 `/ N, l  R- t6 E
其他条件 also for methylcyclopentane% G# o% A+ _4 C* o# }0 A1 s$ k
反应条件6+ m* Z4 ~- U) ^6 N: Z8 t
试剂 H2& [) U% g; y2 T. C/ [
催化剂 OsO4! g! M4 Q! v8 F4 R4 g% |. b
反应时间 15 hour(s)
  t9 O% h1 f* g- b, e% U- t反应温度 120 ℃
7 [; u" {+ U# E6 w反应压强 37503
7 g7 I5 T5 Q5 j" ^6 _产率 90 %" M( ~" Z) q8 P7 V* @
研究目的 Product distribution' ?3 p! q# ?. E- p- i# C
其他条件 different Os-catalysts and concentration; reaction temperatures; other alkanes, cycloalkanes, benzene, toluene
6 F. I* ?8 m, u$ @
[13-14] [15-17]
- y* W6 Q8 Z& l" h
chloro-trimethyl-silan
9 q0 H1 Q2 ?; z0 P9 B+ G, dcyclopentan  M# V0 _0 ]" A* l2 l7 C7 Z3 M
cyclopentyltrimethylsilan1 A! n9 `$ P7 v  K& I# s: q2 M
trimethylsilan# Y4 U. j8 x0 {  \5 t
反应条件1( q2 `. @7 n% X7 \" P2 c; ^
试剂 Ca3 r" K  O0 [  S/ i. s$ L
反应时间 1.5 hour(s)
9 k. y2 [" c1 h; }, Z: U: `产率 1 %
( Y4 C: x. `' L- J其他条件 Ambient temperature7 Z( [) S3 X# o) X( E2 Q( O
[18] 9 J( x$ `8 |/ k) p& C
acetyl bromid
" B; h. f6 A6 R0 T) b8 i7 _- scyclopentan
2 |5 t0 ~( S/ \; E2 t
dicyclopentyl sulfid6 s7 l/ _7 C$ C7 N* {: t
Acetylmercapto-cyclopenta
: ]1 z* _/ u" W5 \9 Q/ q0 D
反应条件1) G( m) i  K$ J0 V8 u# X
试剂 AlBr3, S5 [0 ?! ?" |3 I) ?( y9 Q
. m0 G" w9 D( E0 d0 B) G反应时间 2 hour(s)
5 ?1 o, [  i5 n9 d2 o$ w* f% V5 a反应温度 0 ℃( F" j& j6 e$ j3 ^% N$ A% J
产率 45 %6 Q2 ?6 m5 r: b' r3 o6 k
反应条件2" M  s5 B1 V. U: [
试剂 AlBr3, S/ k& r8 G- Z! C- Z$ O
溶剂 various solvent(s)  J# }" I+ k9 g+ R' F
反应时间 2 hour(s)
4 y2 I& O3 a( m8 x) b1 f# M! K- E( i1 O反应温度 0 ℃
; z: V6 X3 J- k( W% w+ m$ m产率 45 %+ N/ s% |3 D) L4 t3 D' L0 U- W$ P
[19] * u* E; n1 v9 H0 T0 p6 _
allyl-tert-butyl peroxid4 U5 y7 P! u! w9 i, f! m( j2 |' L8 ^
cyclopentan
& q2 _, Y2 V* m3 m) V6 H' g6 j
epoxy-2,3 propyl cyclopentan
8 n& E, V3 N# d, I: W" V2 q% f
反应条件1& _/ g# g8 K' K# {/ c! x- ], X2 X- Q
反应时间 10 hour(s)( {! N! X6 S" I1 k3 d, h* ^+ V  b
反应温度 140 ℃: C9 w: T; j# q) f3 k  c
产率 32 %; `# [: H  B. _* i  }
[20]
9 {2 f* s5 L/ v2 z5 [" n
cyclopentan2 U2 `  ~8 ]) Q
perpentene-4 oate de tertiobutyl: N9 I2 B* J( W% {
5-cyclopentylmethyl-dihydro-furan-2-on
; {. z4 l9 [, z. i& Q8 w  Q- q5 h
反应条件18 M6 y. g8 J1 s1 E2 |
反应时间 4 hour(s)( f: ?# r( t4 X: Y. r& I
反应温度 120 ℃
. c, Z) w0 B* L& O5 ^产率 30 %
( R2 j3 x6 ~, m5 i, |5 l: ~5 B( P
[21] 2 y. Z/ ~$ }3 {( G
cyclopentan
% G+ s: z1 Q$ R8 M$ t4-tert-butyl-2-chloro-cyclohexanon
- ~/ Q+ o+ x5 O" k2 D! Z
cis-4-tert-butyl-2-cylopentylcyclohexanon
' V( j( a$ X  m; n4-tert-Butylcyclohex-2-enon
. d/ s- T; j* [$ y4-tert-butyl-cyclohexanon
+ _* P% {5 d3 J% I
反应条件1
) M) ^: m- ^4 ~! {. o$ y! A: J试剂 zinc6 W, t# x7 p* e8 r
反应时间 15 hour(s)3 N# l$ o, Y( E; U" t  ]- I* S  {
反应温度 25 ℃
# ]0 }( L' z1 S产率 32 %- _3 `, z! G+ P2 `
其他条件 Irradiation# a% k2 b! N' G1 c, M1 [
环戊烷生成的反应
* G" A9 a$ \$ V0 T& d- s
反应物/ z' b' D# C% ?. j: {, K. h
生成物6 w, }- W5 [+ Q# X( u6 k5 U
反应条件+ ?. t1 A. ?. ^5 p' `' U2 Z
参考文献- V1 r% I4 }4 ?% o6 T9 t
cyclopenta-1,3-dien
/ S: V  W9 x+ K  |
cyclopentan
* P5 \6 x, E' i5 n
反应条件1
9 f3 _4 I% e9 U- x( G* q7 t试剂 molybdenum oxide-aluminium oxide catalysts& D- h0 ]6 E0 _5 V. s
反应温度 400 ℃# p. v3 L$ R0 o
反应压强 10297.1
- ^' O. r6 ~- @2 c" L其他条件 Hydrogenation
* ^& Q9 \' r4 q& q+ O反应条件22 z9 x9 u( h0 G" ~: s( m! V( @4 c4 Q
试剂 nickel catalysts5 {* s6 t, Z. \* j
反应温度 180 - 230 ℃) Z/ r: [7 `6 L' _
其他条件 Hydrogenation& x/ L) s2 v: j4 b
反应条件3. d8 z8 Y8 L% n1 T/ r( [
试剂 platinum
5 X' K3 [& L" z# o6 w6 F其他条件 Hydrogenation
- H" l- h8 N5 `1 e8 e" x* w2 Z反应条件48 _0 ~2 Z- ^3 h, j
试剂 nickel" {+ {- t, o$ e$ W4 P# O
其他条件 Hydrogenation
8 D4 w% k/ a, P6 L反应条件5
" v$ f7 d, w( E5 v% U试剂 Raney nickel
! J) C* z  _  m* L3 R8 @反应压强 44130.5 - 51485.6
" D: f& S8 b. J7 F( B) p: {6 K其他条件 Hydrogenation: R% D1 z, J* o
反应条件6! }& P% R- x3 A' i* x) H+ i
试剂 H2, H2PtCl6-(C9H19)3N-(i-C4H9)2AlH-C2H5OH: y8 s1 [, M" E% O, {2 J1 I( r7 l
溶剂 toluene, Z1 u/ K$ N. K% U& f
反应温度 20 ℃5 Y' Y; |1 y9 Z* I
反应压强 300.022 b+ z9 R2 h1 I1 }7 s3 T
反应条件7/ E* B9 Q; d  x. F" H
试剂 H2
3 i$ i" N! b/ v$ M) y1 I9 \催化剂 S-MA-Rh5 O- |7 y+ s5 T* P
反应温度 17 ℃1 J3 S; Y% P1 }3 i' m
反应条件8/ H4 l( L. L  Q% [( z8 T
试剂 H2: s6 t/ r# p' f8 K5 @
催化剂 OsO4
5 e1 `0 P+ F2 w% p5 m" l溶剂 benzene
0 a8 v* ~8 ^* b* Z6 P反应时间 1 hour(s)
5 D9 u# k3 v2 i' Z- x反应压强 18751.5
; H: e/ M$ y9 _& b产率 98 %: d+ v) a& q; j
[14] [22-26] [27] [28-29]
4 u' |1 \# d. O4 a! ?4 n. O# h2 E
cyclopentanon4 ?* h% l/ U2 \$ |
cyclopentan
$ Z2 f9 }- [0 B& g* D
反应条件11 |% A! ?+ u% O; x
反应类型 Reduction" E* b# i7 b- Q
试剂 H2
% M, o9 P2 m3 s催化剂 5 percent Pt/K-10 montmorillonite) l) @1 H! y4 Z
溶剂 bis-(2-methoxy-ethyl) ether
: O! n' U5 }. U& c; _3 t  ~+ j  |反应时间 15 hour(s)1 ^0 d6 U: l0 I
反应压强 37503
( _5 E/ P9 i/ _- v5 n产率 98 %
4 f% C- a- E$ Q反应条件2! L0 _# r4 K5 Z0 R2 t; }5 q
试剂 H2* _3 J% m: x3 s6 Z
催化剂 Ni/Al2O3
7 ]2 l! G9 B  p4 }' k9 h* Y反应温度 190 ℃) G5 g$ P; A; [
产率 24 %
! e4 U# L) s. M; y; R& J; ^+ C% d反应条件3
; o% f$ s& T5 p# _+ J8 Z# l2 w9 s  j试剂 nickel9 O6 p, ^( U5 `- y
hydrogen& \3 w, r+ k4 r$ L: q; V8 r
反应温度 125 ℃
2 |5 Z( ]/ M* d5 i7 w0 u# ^反应条件4, v% t$ O& c/ Z/ P2 g
试剂 amalgamated zinc
! ?! X# I9 ^+ B5 X1 Xaqueous HCl" l' F8 U- [1 T% K
反应条件5' `; B" I, L$ _. h' x6 A
试剂 Raney nickel1 j4 ^- A/ s5 T0 G  G; Y" ~' Z
aqueous ethanol
& d9 K6 G* \/ w+ V7 ~. d$ T- x; X反应条件6
& U# p$ [/ s" ?" X6 {+ ^  o试剂 hydrazine hydrate" E, A) X/ W0 r, O' Z9 Y5 h
KOH3 p" ?' k5 `7 T$ W, ?+ d: A6 g6 h
diethylene glycol-monoethyl ether
' I2 @% J" C6 \1 b6 k$ W3 m反应温度 200 ℃8 u; W" d8 Z/ R( \3 @8 C1 ?
反应条件70 A/ X$ Z( `7 m
试剂 nickel /kieselguhr
" V. ]; M6 {/ S反应温度 200 ℃" Z. }, Y- g  w/ u) M3 p: C6 o
其他条件 Hydrogenation( y- W$ s7 ~; X+ `
反应条件82 V0 e& D# |  j
试剂 tungsten (IV)-sulfide
  G1 h) _: ?, C( P反应温度 32 ℃
% a& u1 [; x: l2 j反应压强 73550.8
, e) d3 w; i' X2 R6 f9 q其他条件 Hydrogenation) M8 L% m0 E+ {( ]) a
[30-31] [32-37] + j: T7 R$ v; i4 G& Z
cyclopenten
  j% w: r) w; N
cyclopentan! l: n1 X8 B# a$ \( e
反应条件13 L2 g/ f3 [9 C" K5 _9 l. b2 a
试剂 chromium (III)-oxide-aluminium oxide contacts
" N; _) ^* D' l* `* |0 `7 n反应温度 450 - 500 ℃; M2 J  Q8 D& i/ T( u
反应条件2$ z) m/ P& ]& R& r
试剂 H2) R8 |5 ^: ^- o4 E! X
催化剂 ZnO9 l$ B( D5 j4 ^( T/ Q/ m
反应温度 89.9 ℃" {, m; R3 F7 S
研究目的 Rate constant" R! ~5 r) J) `! a$ M1 \% z
其他条件 free energy of adsorption, rate of hydrogenation% A& s9 ^) A* X3 v9 e$ e& c4 R0 x% m
反应条件3' g, V% s6 v6 F  f# B& e* J- i
试剂 NiCRASi( B0 z/ F) A" m" G
溶剂 1,2-dimethoxy-ethane
3 Y1 w1 u# y: |( G" P* D& |* Z反应时间 4 hour(s)
9 @7 {# T1 B6 X. L反应温度 45 ℃
8 J3 E! a5 R/ V) n反应条件4
2 m1 ]% m+ r; U2 m/ j试剂 hydrogen
- [: G, j) S5 n- o催化剂 Pt-952( `! L: {# Y: ^! i
' V2 f# D  m( n# Z反应温度 20 ℃
) G% Y+ {5 n" V) J: P研究目的 Kinetics//Thermodynamic data4 R  R: S' W( P4 T, C
其他条件 other temperature; E&a%, other solvents
% `: ?2 y+ b# ~) ]# A) d: {反应条件5
  h9 g8 M- `2 R2 @/ z: ^试剂 1.) disiamylborane; 2.) acetic acid
* F% O+ i! A: [' G. @% Q其他条件 1.) diglyme; 2.) diglyme, 100 ℃, 8 h5 z& i  ~% b# H. H9 p4 A+ E
反应条件6
: b% ]; y. _0 C- l$ l9 ~$ X, }5 l试剂 hydrogen& r: a8 p, z5 a0 j9 o- ?
催化剂 Pt/AlPO4/SiO2/ L+ s& U/ l- b+ \2 _7 b
溶剂 methanol) ?* j0 }- Z- e& O
反应温度 27 ℃
* ^) |* P& I; }反应压强 3750.3
5 C# z' W5 ~( a0 E其他条件 initial reduction rate was determined) n& E% ]+ k( Z( @) Q; U- i' ]2 d0 s
反应条件7
8 k  K5 W# i3 b  Y试剂 H4Ru4(CO)12. e0 p* \0 y% m' p8 c
溶剂 benzene5 r( W" _" g. z$ H/ N, m$ K( h
反应时间 13 hour(s)8 G# D2 q0 Z6 S/ |/ g% i0 L5 ^
反应温度 25 ℃
% S9 g* e1 Q& y; M, W& L1 A  [其他条件 Irradiation+ _4 z- N4 O" t9 o5 y/ @
反应条件8
# q! n9 K1 ]0 ^6 W试剂 H4Mo(DPPE)23 q4 a0 s& `8 p" X8 X
溶剂 toluene) P3 I& B# z" E
反应时间 24 hour(s)
. \5 l3 c7 w; n0 {) C" r- Q8 s其他条件 Irradiation
1 ]7 o5 G$ \' ~. s0 f* v1 x反应条件9- F  K# C0 w' J$ R* S7 N
试剂 H2, H2PtCl6-(C9H19)3N-(i-C4H9)2AlH-C2H5OH. R! l( `: U8 h
溶剂 toluene) K7 s) v# H  h1 k8 N6 y! ?* {
反应温度 20 ℃
! N+ W5 |: ~. i& n反应压强 300.02+ C6 T7 d. x5 y7 y  i
其他条件 further reagents/ X" S# V# ?: k
反应条件10
" D$ x. @/ d9 ]/ _4 D* k试剂 H2, ZnO0 Q' _( b3 }. o* C: S
反应时间 100 min
& M( b1 {( r  b7 ~# a( m反应温度 89.9 ℃# D$ d, v5 V% a! N
研究目的 Product distribution//Kinetics//Thermodynamic data
  u( P+ O8 _' }8 N. ?其他条件 further temperatures and pressures; kinetic isotope effect, E(activ.)
9 ?" [" J8 W. L' r( O4 Q反应条件11
. i- Y! @1 p! x# w试剂 H2; H/ p: H0 \& G# ]- O
催化剂' N! G8 w7 w+ M* t0 `0 ^; N
反应温度 23 ℃
6 e, x4 m4 I/ f6 b* p! X反应压强 2280
6 G, ]; T: _$ }! m3 y/ p% b反应条件12
3 b" X% x0 k) L试剂 palladium-contacts3 e- s: L* @# i! _! J- V
反应温度 180 - 200 ℃2 }0 T! q& k$ f# k
反应条件13
" B+ a+ c0 M1 y" u  S2 y! M/ ?试剂 Raney nickel; S" L/ H. E. s/ M: V/ S/ E
2 ~' A% H8 ]: x5 H6 R其他条件 Hydrogenation
5 _( @. R. f3 ?4 Z0 k4 B- `反应条件14
0 B! Z% Q* c: z, X* U4 n! W试剂 platinum black
7 e% d1 u$ _2 k+ g1 H6 {/ ^其他条件 Hydrogenation/ N4 {( G3 Z* i# a
反应条件15/ @, M9 z( |+ @' ^( a( u' x: M  y
试剂 platinum black
( |  ^" L3 w6 a6 p1 A2 w  b2 l2 iglacial acetic acid
( m* j, n& D0 k* E. L' i2 t; J其他条件 Hydrogenation; h  Q$ B" }: N9 M
反应条件16! L1 a- u2 G' j& u' e: E% D4 B
试剂 nickel9 i3 [. H( L, L* i! f% y* `/ X( Z: g
hydrogen! s! Q! W& _" V0 N; M0 n$ |8 D
反应温度 125 ℃! r3 b& N' ]6 y
反应条件17
8 X2 l# ]7 J! }  b- r试剂 platinum
) ^' D% G( ~; r3 D. D) `3 sethanol! @# A3 y5 ~1 ?8 ]  Q
其他条件 Hydrogenation
+ A5 z# T" e* H# y反应条件18
4 M% l, d0 A1 S+ S/ s4 v试剂 hydrogen
/ B( U. D- n' M+ g! A9 |/ L催化剂 (PhP)2Pd5+ Q" k  _( A+ X! V
溶剂 dimethylformamide5 Q! l7 B$ e) M
反应温度 20 ℃
9 c3 J" L9 t5 ?# p反应压强 760
+ ~% l0 u4 k( k1 I; u研究目的 Rate constant
. p: {5 ]9 Y$ j+ v; [. m" F/ V% I反应条件19- c* \+ M, u0 g1 Q
试剂 H2: h; j$ b8 f0 h/ s* z6 a3 Y
催化剂 Rhodium chloride tri(triphenylphosphine-meta-trisulfonate)$ a4 X. a- I9 K, V1 j0 A
溶剂 H2O. _. ]- D( h% e7 t% R. o  n
反应时间 8 hour(s)
' P, R( z: z8 V/ U$ A$ @$ [产率 95 %
0 y2 k, i$ }& E7 Y& {. K; `5 x  E其他条件 Ambient temperature; b6 F2 k; x) F; T
[31] [27] [38-50] [51-54] 1 `1 |: H  o6 u5 F
bromocyclopentan
/ G( G- j4 r2 |
cyclopentan
3 A* v$ ?$ o! x  n: RBicyclopenty
+ K/ X6 I$ j: n4 R! Kcyclopenten2 P8 x, a7 Q1 r( M: F% s
cyclopentylmagnesium bromid7 v$ P- y) U1 F* w' h  P7 b2 a
反应条件1
% E  ?2 K7 z  Q, b6 T* X试剂 Mg
/ \4 K% J1 }: d9 q* p溶剂 diethyl ether+ j' z$ |- ]7 R1 g% Q
反应温度 0 ℃
- J" b/ @# J# m% S1 G9 Q! ^3 N产率 50 %
9 E! }: `+ K  c9 c' |5 [; Y0 b; b; n研究目的 Mechanism//Rate constant" A. P9 w' G9 N* R6 q& X% u" x9 G
其他条件 reaction rate dependence on angular velocity of disk, solution viscosity- Y) e" N$ u1 ]2 T
[55]
( J3 G+ `3 v& p: ^
cyclopentano( w' N& p0 u# I' g! s. G8 A
cyclopentan, @& Q+ g. o3 r4 Y0 Y. X- U% E) U
反应条件1
- n1 P. E0 ^4 ?& E: c试剂 H2
! p; y5 m) `& d催化剂 iron promoted by V2O5* F4 Z7 E3 @. m  Z. F6 Y
反应温度 326.9 ℃" i; {" X' s+ T/ X; M5 f  V1 a: q
其他条件 1.5E5 Pa# z6 w, x! o/ d" D. h4 m
反应条件2
6 B, V. N7 ~9 l2 {试剂 H2  `, ~3 w% x( f7 ]) f7 X. O
催化剂 Ni& I/ A5 F. p* t  r$ ^. O' y6 s2 V
反应温度 180 ℃
5 w3 A- p% B7 U0 u+ ?4 p产率 95 %1 m+ k: h7 I; @0 h
[56-57]
8 U1 W, H9 [6 D
cyclopentanecarboxylic aci- @# r+ e6 x) q$ A8 H
cyclopenten9 s, Q- E; \$ S2 p+ z5 g
cyclopentan2 v! o5 a4 a5 Z; o* f2 s" L
反应条件1
0 |9 K+ ?$ `7 h2 F) ?* ]4 p试剂 H2
$ T% x# u4 I7 W, _  R' ?0 k催化剂 Pd/SiO2* b* U. O+ g9 z$ ?3 B
反应温度 330 ℃9 k8 b) Z" ?1 H( P
产率 40 %
$ V7 v9 k; ]* b% B反应条件2
7 B4 R0 c/ U. i试剂 H2& [0 H% K% a- ~- x4 C
催化剂 Pd/SiO2
, D/ Y, Q+ K6 l5 o* Y反应温度 330 ℃4 I$ b" Z0 w  X7 u% a8 L! x
产率 45 %
0 [3 A" A) U, [5 a0 F' v
[58] / O" g0 N) W/ k+ y; \
2-Cyclohexyl-pheno, K& Z0 Z) c6 \' H6 m  `
methylbenzen- Z+ F% u; Z0 \
benzen
1 J/ Q4 v7 \9 m2 d5 k* I( Hcyclopentan
2 b4 C) R6 n5 [7 c4 B2 umethylcyclopentan+ _( W) f1 n' s( H. C4 s0 _, B
cyclohexan) Q" P& I2 z5 X! L$ c4 b
cyclohexylbenzen
6 \* p( x# R, p, @1 v% x0 `
反应条件1
! c- M7 r  S4 ~( v0 A试剂 H22 K/ Z( Y# C6 ]* `+ x
催化剂 MoO3-NiO/Al2O3" H4 K8 d7 B! E" k# L: r
反应时间 45 min
! T, K3 p, m. v2 J7 [; {反应温度 450 ℃
. ^( S3 h* V) F1 `1 u! P9 s反应压强 21001.7
0 o* m+ S  Y$ d  j. Y5 w- ?; f- I产率 14 %2 g& o$ L+ U, S, l; E" C( o$ N7 O
研究目的 Product distribution( U" g" f, s) \1 U* A
其他条件 further products
; y# S+ t' {3 H! a5 _2 c
[59] 0 W/ [; ]7 i0 }, j2 Y4 D9 ^
cyclopenten
5 V/ N' G! Y# W7 c6 A/ `; kmethan
! w% J  Y. p- a* K% c5 ]4 @
cyclopentan
5 y$ o' H* W' Kmethylbenzen
9 L' W* z# \! m5 `: `. [benzen6 I6 I3 l9 f0 j, K' X: @+ z
反应条件1
( k! h$ g, y* @8 b催化剂 20 percent Ni on sodalite
3 e% r6 X% M5 \. ^8 c8 a反应温度 310 ℃
: ^  f7 q# H  R! t+ c反应压强 735.5! d& P" k( y6 ~  h
产率 9 %# q) m+ q5 I. @, _3 ]- L
反应条件2
# x6 E4 U% n- R0 L% T催化剂 20percent Ni on sodalite
: ]' k' g. U: C$ D2 ^4 \反应温度 310 ℃
  X' c4 k4 `; B# m反应压强 735.5
- `! n; m' n! M* D5 j( w7 d4 W产率 33 %& t4 \5 ]5 }. r( ?/ |
[60]
3 d1 w. {; o; R/ \
cyclopentylmagnesium bromid" D( F8 g' p( s& s  Z5 M4 S! @- R
cyclopentan
9 l" E; J1 R  y2 Y, o2 v+ @0 c
反应条件19 N+ w( a" h; U. ?- d. k2 c5 X
试剂 2,2,6,6-tetramethylpiperidine nitroxil, tert-butyl alcohol) f7 T/ U5 @# G# u
溶剂 diethyl ether
+ J, M5 z. t$ ?- ^$ y* P2 o: T反应温度 34 ℃
3 ~0 b% r2 {  ?( C1 m% O" h产率 98 %
8 V1 ]% {) k9 C! k; T
[61] ! N0 a* ]: \+ s& D) l- i8 t8 S
cyclopentylmagnesium bromid" Q3 f1 J3 l' i  ?# x- U; G1 Y
cyclopentan
* F/ I+ D+ [" S' k. pBicyclopenty6 I4 g# p$ y+ S+ d% Z
cyclopenten) p( u2 P, s  [6 N( J
反应条件1
9 y& Z# g: U. l% ~; |9 d6 K# X. b. ?试剂 CuCl2% J2 @/ f9 J0 r( J7 p) ]
溶剂 diethyl ether. ~- X2 D- d0 q# E4 w5 l7 A. \3 ?
反应温度 0 ℃" j7 d. [6 z, N$ x# g
产率 1 %: l, }" w1 x3 g, v. D/ E) ?: A( v
参考资料
% w9 F( O/ \; X1.  环戊烷  .化工字典[引用日期2017-04-18]
0 f1 F* d, I4 g4 ?. j+ S; C2.  Diaz-Requejo, M. Mar; Belderrain, Tomas R.; Nicasio, M. Carmen; Trofimenko, Swiatoslaw; Perez, Pedro J.; J. Amer. Chem. Soc. . 2002,124,(6),896-897.  V7 y  Z+ }0 N) L" ~
3.  Vaughan; Rust; J. Org. Chem. . 1940,5,468.) o: c8 H) A9 j$ i+ T* {( H
4.  DRP/DRBP Org.Chem.;DE;N. V. de Bataafsche Petr. Mij.;DE 746888;1940;
4 d: ?' R# f8 M3 l+ O# `) E5 u5.  Shell Devel. Co.;US 2342072;1940;
0 ^( v/ _, a+ Z& ?9 h6.  Olah, George A.; Wu, An-hsiang; Farooq, Omar; J. Org. Chem. . 1989,54,(6),1463-1465.( N( h6 o# z- |+ N$ u6 _
7.  Davis, Reg; Durrant, Jim L. A.; Rowland, Christopher C.; J. Organomet. Chem. . 1986,316,147-162.
( j* m2 Q1 X7 y! @, t" G7 Y8.  Isbell; Wadsworth; J. Am. Chem. Soc. . 1956,78,6042,6044.
% D7 e: h3 p, S, r. p9.  Olah, George A.; Farooq, Omar; Wang, Qi; Wu, An-hsiang; J. Org. Chem. . 1990,55,(4),1224-1227.
1 _/ w, f! n  }: l* l: ^3 ]) u10.  Nametkin; Zh. Russ. Fiz. -Khim. O-va. 1911,43,(I),1605.
2 N: L' q6 T& j% x$ `3 a: P" w11.  Nishiwaki, Yoshiki; Sakaguchi, Satoshi; Ishii, Yasutaka; J. Org. Chem. . 2002,67,(16),5663-5668.: D; Z& ^, |! F% i
12.  Kasanski; Bulanowa; Izv. Akad. Nauk SSSR Ser. Khim. . Chem.Abstr.;1947,29.
+ u3 Z. N" n  E1 ~( Q) `13.  Zelinski; Kasanski; Plate; Chem. Ber. . 1933,66,1415,1419.
7 ^  s0 J) Q) ~+ J4 i/ q14.  Akhrem, I. S.; Reznichenko, S. V.; Grushin, V. V.; Simonova, O. Yu.; Christovalova, N. M.; Vol'pin, M. E.; Bull. Acad. Sci. USSR Div. Chem. Sci. (Engl. Transl. ). 1989,38,(11.1),2229-2233.
- Q& O* Y! X# i15.  Apesteguia, C.; Barbier, J.; Bull. Soc. Chim. Fr. . 1982,1,(5-6),165-168.. y: F2 T2 j1 j7 L$ q+ a
16.  Akhrem, I. S.; Reznichenko, S. V.; Vol'pin, M. E.; Bull. Acad. Sci. USSR Div. Chem. Sci. (Engl. Transl. ). 1984,33,(9),1969.: j! Q  _$ }' g8 Q6 a
17.  Mochida, Kunio; Kojima, Kenji; Yoshida, Yasuhiro; Bull. Chem. Soc. Jpn. . 1987,60,(6),2255-2256.
+ ]) U7 I: W( J0 I9 M0 I18.  Orlinkov, A. V.; Akhrem, I. S.; Afanas'eva, L. V.; Vitt, S. V.; Vol'pin, M. E.; Bull. Acad. Sci. USSR Div. Chem. Sci. (Engl. Transl. ). 1991,40,(1.1),90-92.
  f; ~' B7 Y1 V19.  Maillard, B.; Montaudon, E.; Rakotomanana, F.; Bourgeois, M. J.; Tetrahedron. 1985,41,(21),5039-5044.$ M* V8 c5 y5 j8 J0 d
20.  Maillard, B.; Kharrat, A.; Gardrat, C.; Tetrahedron. 1984,40,(18),3531-3538.
: k# f- A  k8 E7 k0 L21.  Morrison, Harry; Cardenas, L. de; J. Org. Chem. . 1987,52,(12),2590-2592.
9 Y0 r9 }! i9 b: h: ^; Z22.  Eijkman; Chem. Zentralbl. . 1903,74,(II),989.9 e2 u; {6 Z9 B2 T5 H) i
23.  Grosse; Ipatieff; J. Org. Chem. . 1937,2,447,450.$ z0 M* X7 C1 Y# v# {6 j
24.  Hofmann et al.; Brennst. Chem. . 1933,14,103,105.
7 g- K1 H& U0 I: x) N# B9 \25.  Anglo-Iranian Oil Co.;US 2407214;1943;, G' U7 L) B% n; E
26.  Kasanskii; Terent'ewa; Sint. org. Soedin.;1950,1,158;dtsch.Ausg.S.58.' ^+ H# d% }1 H! R; M  t8 t
27.  Kliger, E. G.; Shuikina, L. P.; Parenago, O. P.; Frolov, V. M.; Bull. Acad. Sci. USSR Div. Chem. Sci. (Engl. Transl. ). 1988,37,(10),2182-2184.3 A% U2 [" q- z- f
28.  Karakhanov, E. A.; Pshezhetskii, V. S.; Dedov, A. G.; Loktev, A. S.; Lebedeva, T. S.; Dokl. Chem. (Engl. Transl. ). 1984,275,135-136.
& R) c! J8 L1 ^  M3 X1 s29.  Roberts; Sauer; J. Amer. Chem. Soc. . 1949,71,3925,3928.
( E; O% V! v  O. T0 P! a1 l30.  Mozingo; Spencer; Folkers; J. Amer. Chem. Soc. . 1944,66,1859.
. G+ L* h% M4 F7 l31.  Godchot; Taboury; Ann. Chim. (Paris). 1912, 26,43,47.
/ }5 c5 q" s" v; p& O0 c+ G0 l32.  Nenitzescu; Cantuniari; Chem. Ber. . 1932,65,807,811.
, D4 I1 r4 j/ Y# q33.  Landa; Mostecky; Collect. Czech. Chem. Commun. . 1955,20,430,432.3 l8 h: L1 R1 y
34.  Mechtiew et al.; Dokl. Akad. Nauk SSSR. Chem.Abstr.;1954,99,773.
+ j1 e2 ]" y. d! {& O; W/ a35.  Maier, W. F.; Bergmann, K.; Bleicher, W.; Schleyer, P. v. R.; Tetrahedron Lett. . 1981,22,(42),4227-4230.
+ e) s" V% x2 @( n  n36.  Toeroek, Bela; London, Gabor; Bartok, Mihaly; Syn. Lett. . 2000,(5),631-632.4 m9 ~" X" ]4 i; x& A
37.  Chavanne; Bull. Soc. Chim. Belg. . 1922,31,(IV),334.
: E' v1 ^% i* p38.  Eisenlohr; Chem. Zentralbl. . Fortsch. Ch., Phys.;1926,18,(I),540.
1 D* n: s0 I/ }/ k6 y8 f9 N7 i39.  Heisig; J. Phys. Chem. . 1935,39,1067,1072.0 X2 k- D. s8 e$ A$ G0 l* o6 `" i
40.  Plate; Batujew; Zh. Obshch. Khim. . Chem.Abstr.;1946,16,805,806.' q0 J( S5 @0 s/ ^5 ~& a
41.  Vogel; J. Chem. Soc. . 1938,1323,1328.
3 T; n, H" s! ]* r7 Z42.  Kasanskii et al.; Sint. org. Soedin.;1950,1,161;dtsch.Ausg.S.60.
. {: b5 T/ @% D! g2 q  I43.  Larpent, Chantal; Dabard, Renee; Patin, Henri; Tetrahedron Lett. . 1987,28,(22),2507-2510.
; \/ a" d( s$ q+ R! g9 n44.  Fort, Y; Vanderesse, R; Caubere, P; Tetrahedron Lett. . 1986,27,(45),5487-5490.
$ ^/ i/ v7 S7 f7 {45.  Brown, Ronald; Kemball, Charles; Taylor, Duncan; J. Chem. Soc. Faraday Trans. 1. 1983,79,2899-2914.
0 E) A: |4 s) E7 P. }0 a; W; y3 U46.  Brown, Herbert C.; Murray, Kenneth J.; Tetrahedron. 1986,42,(20),5497-5504.
7 g3 h* C" }$ y9 @47.  Graff, James L.; Wrighton, Mark S.; J. Amer. Chem. Soc. . 1980,102,(6),2123-2125.
* x, D' n( @. s, ?# B48.  Aramendia, M. A.; Borau, V.; Jimenez, C.; Marinas, J. M.; Acta Chim. Acad. Sci. Hung. . 1982,110,(1),97-101.4 N4 p! Y5 ]# g0 @7 _& }
49.  Graff, James L.; Sobieralsky, Ted J.; Wrighton, Mark S.; Geoffroy, Gregory L.; J. Amer. Chem. Soc. . 1982,104,(26),7526-7533.) t3 K' Q4 K5 t
50.  Kawai, Tadashi; Jarjoui, Milad; Burwell, Robert L.; J. Amer. Chem. Soc. . 1982,104,(11),2951-2956.
; B3 [0 H( Q! i2 O! P$ p51.  Berenblyum, A. S.; Mund, S. L.; Danilova, L. G.; Moiseev, I. I.; Bull. Acad. Sci. USSR Div. Chem. Sci. (Engl. Transl. ). 1981,30,(4),686-689.
3 o! `2 P$ v6 b8 Y' o8 B52.  Brown, Ronald; Kemball, Charles; Taylor, Duncan; J. Chem. Res. Miniprint. 1982,(9),2329-2350.9 |( E8 i+ Q3 H
53.  Barry, Jane T.; Chisholm, Malcolm H.; J. Chem. Soc. Chem. Commun. . 1995,(15),1599-1600.% O: l# A" m2 D7 f) ^
54.  Root, Karen S.; Deutch, John; Whitesides, George M.; J. Amer. Chem. Soc. . 1981,103,(18),5475-5479.; R* h* Q/ ]- U: ~$ l' N, F
55.  Glebov, L. S.; Mikaya, A. I.; Yatsenko, A. E.; Zaikin, V. G.; Kliger, G. A.; Loktev, S. M.; Tetrahedron Lett. . 1985,26,(28),3373-3376.0 d1 m! C9 d/ R- ^
56.  Maier, Wilhelm F.; Thies, Irina; Rague Schleyer, Paul von; Z. Naturforsch. B Anorg. Chem. Org. Chem. . 1982,37,(3),392-394.
8 T1 @! P1 p! H: o& C6 M% o57.  Maier, Wilhelm F.; Roth, Wolfgang; Thies, Irina; Schleyer, Paul Rague v.; Chem. Ber. . 1982,115,(2),808-812.8 }6 _' ?% o; V7 o) @
58.  Kallury, R. K. M. R.; Tidwell, T. T.; Boocock, D. G. B.; Chow, D. H. L.; Can. J. Chem. . 1984,62,2540-2545.
% y) M$ l+ r' A8 O$ @59.  Loeffler, Ingolf D.; Maier, Wilhelm F.; Andrade, Juan G.; Thies, Irina; Schleyer, Paul von Rague; J. Chem. Soc. Chem. Commun. . 1984,(17),1177-1179.
8 @6 c: `6 _+ r# k, c60.  Lawrence, Lynnette M.; Whitesides, George M.; J. Amer. Chem. Soc. . 1980,102,(7),2493-2494.3 P- K& F' C" ]8 o
61.  Jackisch, Joerg; Legler, Jochen; Kauffmann, Thomas; Chem. Ber. . 1982,115,(2),659-668.
- [7 x0 l& }) d% {4 G+ p
待增加
' Y$ A: M; d3 M) v1 n
本内容贡献者
. i3 c5 t3 w, h. [, Z
* o$ h- P; B9 C
发表于 2021-1-25 14:43:46
当前内容由会员用户名 零落浮华 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.063477 second(s), 37 queries , Redis On.
