[讨论] 工芯匠技:废水处理厂国产压力变送器应用运行管理应用(02
1.1K |1
saurfang~赤焰浮屠VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP陕西省
工业污水处理种类繁多,化工、制药、食品等行业废水处理外;不同行业工程污水处理有典型的特征。
水污染指标(Water pollution index
  水污染指标是衡量水体被污染程度的数值标示,也是控制好检测水处理设备运行状态的重要依据。其中,最常用的水污染指标有(8个)(Water pollution inde*s a numerical indicator to measure the degree of water pollution and an important basis to control the running state of water treatment equipment. Among them, the most commonly used water pollution indicators are (8):
  生化需氧量(BOD):表示在有饱和氧条件下,好氧微生物在20℃,经一定天数降解每升水中有机物所消耗的游离氧的量,常用单位mg/L,常以5日为测定BOD的标准时间,以BOD5表示。(Biochemical oxygen demand (BOD) : represents the amount of free oxygen consumed by aerobic microorganisms to degrade organic matter in every liter of water at 20℃ for a certain number of days under the condition of saturated oxygen. It is commonly used in unit mg/L. BOD is usually measured in 5 days and expressed as BOD5.
  化学需氧量(COD):表示用强氧化剂把有机物氧化为H2O和CO2所消耗的相当氧量。常用的氧化剂为重铬酸钾或高锰酸钾,分别表示为CODCr或简写(COD)和CODMn(也称耗氧量,简称OC),单位为mg/L。(Chemical oxygen demand (COD) : refers to the equivalent oxygen consumption of o*dizing organic matter into H2O and CO2 with strong o*dant. The commonly used o*dants, potassium dichromate or potassium permanganate, are expressed as CODCr or COD or CODMn(also known as oxygen consumption, or OC) in mg/L
  总需氧量(TOD):当有机物完全被氧化时,C、H、N、S分别被氧化为CO2、H2O、NO、SO2时所消耗的氧量,单位为mg/L。(Total oxygen demand (TOD) : when the organic matter is completely o*dized, the oxygen consumed when C, H, N and S are o*dized into CO2, H2O, NO and SO2 respectively, the unit is mg/L.
  总有机碳(TOC)Total organic carbon (TOC):表示水中有机污染物的总含碳量,以碳含量表示,单位为mg/L。
  悬浮物(SS):水样过滤后,滤膜或滤纸上截留下来的物质,单位为mg/L。
  pH:表示污水的酸碱性。(Is the total carbon content of organic pollutants in water, expressed in terms of carbon content, expressed in mg/L.
Suspended solids (SS) : substance trapped on the filter membrane or filter paper after water sample filtration, in mg/L.
PH: refers to the acidity and alkalinity of sewage.
  有毒物质:表示水中所含对生物有害物质的含量,如氰化物、砷化物、汞、镉、铬、铅等,单位为mg/L。(To*c substance: refers to the content of biological harmful substances in water, such as cyanide, arsenide, mercury, cadmium, chromium, lead, etc., in mg/L
  大肠杆菌数:指每升水中所含大肠杆菌的数目,单位为个/L。
    (1)印染废水处理过程中,不同的染料所排放废水水质不同,处理难度也不同。印染行业时耗水大户,将印染废水处理达标的同时进行深度处理回用,对印染废水进行清污分流进行综合利用,大幅降低用水量。
    (2)造纸污水处理时水量大,再生纸废水处理废水中含有大量的钙盐,易结垢;此外**要求进行中水回用,帮助用户解决废水处理中硬度过高钙化问题和将废水深度处理后回用;应邀帮助理文造纸、江门明星纸业等提供技术支持。
    (3)饲料废水处理:饲料废水来源于饲料生产过程中废气喷淋除臭产生的废水和场地清洗废水,废水中含有易生物降解的饲料粉末。采用生物技术将饲料废水处理至回用标准,循环回用至饲料废水喷淋处理过程,实现污水零排放回用。现已建成20余座饲料废水处理回用工程。
    (4)淀粉废水处理时,废水中含有植物蛋白和硫酸盐,此外还有淀粉颗粒随着污水流出,会导致污水浓度上升和处理难度加大,必要时进行预处理。
    (5)柠檬酸废水处理时,由于含有大量的有机酸,因此污水处理过程中要避免挥发脂肪酸(VFA)积累。
   不同废水的处理方法不同,需根据不同的生产企业定制专业的污水处理方案并实施,才能有效将工业污水处理达标排放。
  在废水使用中需要大量的仪表来完成化工自动化数据采集,和现场勘控,作为国产压力变送器厂家,提供:压力(表压)/绝对压力变送器,是以大气压/真空为参考端测量的压强信号,只有一个端口
和工艺管道链接。
9a821e843a0cc05eb22c36a37120f590.webp 金属电容式压力(表压)/绝对压力变送器工作原理,当压力通过隔离膜片和导压介质间
作用在不同厚度的金属测量膜片弹性测量元件)的表面,使膜片产生微小的变形,
最大变形不超过0.1mm,高精度测量电路将这个微小的形变转换层一个与压差信号成线性关系
的电压信号,进故宫线性化,温度补偿,然后采用专用芯片将这个电压信号转换为工业标准的4-20ma电流信号或1-5V电压信号。
由金属电容式压力传感器的高灵敏度和测量膜片检测电路采用的高精度集成电路,内部包含
线性及温度补偿电路,所以整个变送器都可以做到高精度和稳定性。
金属电容式极高的抗过载性能和在微压测量方面的优异表现,更适合中国复杂的工业环境现场的必选产品。
凡是在两个平面周边使用螺栓连接同时封闭的连接零件,一般都称为“法兰”,
华恒变送器厂家研发出传感器和智能电路板两项核心技术,不仅所有产品的核心部件技术全部掌握,工业自动变送器厂家的精确度也在不断提高,由0.2级提高到0.1级。还可通过对所掌握核心技术进行延伸,变形出测流量、测温度的其他产品。
华恒变送器厂家凭借自身拥有的传感器和智能电路板核心技术,可以根据客户要求,低成本对核心技术进行延伸变形,实现个性化产品定制。主要产品有SMART(斯玛特)系列压力变送器、多参数变送器、流量器、温度传感器和物位(液位变送器厂家,为我国电力、石油、化工、冶金、水泥、矿业等行业提供了高性能价格比的工业自动变送器厂家产品.
发表于 2019-11-4 17:07:07
【提示:直接搜索2844385可直达本帖。】
当前内容由会员用户名 saurfang~赤焰浮屠 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
发表于 2019-11-4 20:40:07
海川化工论坛网(hcbbs) @Discuz! X3  加载0.058203 second(s), 33 queries Redis On.
