海奥膜
[讨论] PROⅡ模拟甲醇三塔精馏操作这些warning怎么解决
1.4K |1
书天VIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP天津市
*** PROBLEM SOLUTION BEGINS
** WARNING **  The liquid enthalpy of CO2 at temperature 305.15 K is outside
                the acceptable range of 220 K through 290 K.
** WARNING **  The liquid enthalpy of DME at temperature 305.15 K is outside
                the acceptable range of 131.65 K through 250 K.
     FEED FLASH    COMPLETE
       Loop  1     BEGINS   - 'LOOP1       '
** WARNING **  PRESSURE of feed STREAM 6, 'FEED2' = 1.4921 is LESS THAN the
                feed TRAY PRESSURE of 9.191 on tray 36.
** WARNING **  The liquid enthalpy of ACETONE at temperature 351.32 K is
                outside the acceptable range of 178.45 K through 329.44 K.
** WARNING **  The liquid enthalpy of MTBE at temperature 351.32 K is outside
                the acceptable range of 164.55 K through 328.35 K.
** WARNING **  The liquid enthalpy of ACETIC at temperature 411.32 K is
                outside the acceptable range of 289.81 K through 391.05 K.
** WARNING **  The liquid enthalpy of METHANOL at temperature 411.32 K is
                outside the acceptable range of 175.47 K through 400 K.
** WARNING **  The liquid enthalpy of ETHANOL at temperature 411.32 K is
                outside the acceptable range of 159.05 K through 390 K.
** WARNING **  The liquid enthalpy of BUTANOL at temperature 411.32 K is
                outside the acceptable range of 184.51 K through 390.81 K.
** WARNING **  The liquid enthalpy of PROPANOL at temperature 411.32 K is
                outside the acceptable range of 146.95 K through 400 K.
发表于 2019-9-27 20:52:26
【提示:直接搜索2789213可直达本帖。】
当前内容由会员用户名 书天 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
伟仔_UZLNVIP会员 VIP会员 | 显示全部楼层       最后访问IP重庆市
你这个物流相态有问题,检查一下进口温度,压力,塔压检查一下,多嘴一句,始终要知道模拟就是利用其数据库和运算能力,完全什么都不知道就模拟,你模拟出来结果是不可信的。
发表于 2019-9-30 09:21:07
海川化工论坛网(hcbbs) @Discuz! X3  加载0.292499 second(s), 46 queries Redis On.
