[原创] Orifice Plates and Venturi Tubes
1.5K |0
liurunzeVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP内蒙古自治区
Orifice Plates and Venturi Tubes  书籍
Orifice Plates and Venturi Tubes (Experimental Fluid Mechanics)
Orifice Plates and Venturi Tubes (Experimental Fluid Mechanics) By Michael Reader-Harris
2015 | 412 Pages | ISBN: 3319168797 | PDF | 16 MB
This book gives the background to differential-pressure flow measurement and goes through the requirements explaining the reason for them. For those who want to use an orifice plate or a Venturi tube the standard ISO 5167 and its associated Technical Reports give the instructions required. However, they rarely tell the users why they should follow certain instructions. This book helps users of the ISO standards for orifice plates and Venturi tubes to understand the reasons why the standards are as they are, to apply them effectively, and to understand the consequences of deviations from the standards.
- 本文出自ASME中国制造,原文地址:http://www.asimi8.com/thread-32436-1-1.html
发表于 2017-10-12 08:52:43
Orifice Plates and Venturi Tubes (2015).zip
8.89 MB, 下载次数: 1, 下载积分:财富 -10 财富值
另需要【20  财富值】  [记录]
【提示:直接搜索1850998可直达本帖。】
当前内容由会员用户名 liurunze 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
海川化工论坛网(hcbbs) @Discuz! X3  加载0.054607 second(s), 33 queries Redis On.
