[讨论] PDMS中如何打断 利用ASL创建的栏杆
3.3K |1
汪皓_n9STFVIP会员 VIP会员 | 显示全部楼层 |阅读模式       最后访问IP浙江省
阅读了一下手册上 用GATE 还是不懂 怎么创建 创建不出来
Populating the form grid object with the Handrail Gate data is done using the Add Gate link,
once picked the system will prompt the user to 'Pick position to insert GATE:' as indicated
below. A graphical indication on the Handrail element will derive a position along the
Handrail path and a graphical preview of the position and size will be displayed along with a
numerical identifier corresponding to the number of Handrail Gate's in the Platform Feature.
The X/Y position of the Handrail Gate is derived by the system from the path of the Routing
Path element, the Handrail Gate origin is at the centre of the opening and coincident with
the Platform elevation.
发表于 2019-12-12 21:40:59
xiamingteda + 5 发起议题
当前内容由会员用户名 汪皓_n9STF 发布!权益归其或其声明的所有人所有 仅代表其个人观点, 仅供个人学习、研究之用。
汪皓_n9STF楼主 VIP会员 VIP会员 | 显示全部楼层       最后访问IP浙江省
做完后 已解决 用 MOVE CURRENt VERTX 改变起点
发表于 2019-12-12 22:54:26
xiamingteda + 5 积极参与
海川化工论坛网(hcbbs) @Discuz! X3  加载0.230525 second(s), 61 queries , Redis On. | 网站统计 |
