化海川流-海川化工论坛网
用户名账户登录
用户名密码方式登录
QQ
企业信息流  -  [ 详询客服 ]
头版信息
压力容器资料整理→ collect Pressure vessel document
1242 |1
ningyong58VIP会员 VIP会员 发表于 2014-8-25 20:37:22 | 显示全部楼层 |阅读模式   来自甘肃省
海川初中3年级   昵称头衔:  Ta暂未定义 - 配置你的头衔
加入hcbbs与近480万工业人互动
您需要 登录 才可以下载或查看,没有帐号?注册
FAQS(Frequently Asked Questions)的缩写。
常见问题(解答)
例如: please read the FAQ before asking any questions!
1 What is a pressure vessel?
A pressure vessel is defined as?"a vessel in which the pressure is obtained from an indirect source or by the application of heat from an indirect source or a direct source. The vessel proper terminates at: (a) the first circumferential joint for welded end connections; (b) the face of the first flange in bolted flange connections; or (c) the first threaded joint in threaded connections." Pressure vessels include but are not limited to compressed gas storage tanks (i.e., air, oxygen, nitrogen tanks, etc.), anhydrous ammonia tanks, hydro pneumatic tanks, autoclaves, hot water storage tanks, chemical reactors and refrigerant vessels, designed for a pressure greater than 15 psi and a volume greater than 5 cubic feet in volume or one and one-half cubic feet in volume with a pressure greater than 600 psi.
vessument ?  发表于 2014-8-26 11:48
个人评分
查看全部
声明:当前内容由会员用户名 ningyong58 发布!权益归其或其声明的所有人所有 仅代表其个人观点,仅供学习交流之用
本主题及回复中的网友及版主依个人意愿的点评互动、推荐、评分等,均不代表本站认可其内容或确认其权益归属, 也不代表本站立场
平台上的信息及推广等由会员分享发布,浏览者请自行判断其内容真实性或可用性,并自负因使用相关信息造成的后果
本站系信息发布平台,仅提供信息存储服务,如您对此内容存在争议或认为侵犯您的权益,可联系我站举证删除处理,我站在线客服或致信service@hcbbs.com 188-4091-1640网站声明
ningyong58楼主 VIP会员 VIP会员 发表于 2014-8-25 21:13:54 | 显示全部楼层   来自甘肃省
2  Requirements for Boiler and Pressure Vessel Manufacture Licensing
锅炉和压力容器制造许可
Article 1. The Requirements for Boiler and Pressure Vessel Manufacture Licensing
are specially formulated in accordance with relevant requirements in the Supervision
Administration Regulation for Manufacture of Boiler and Pressure Vessel (hereinafter
referred to as the "Administration Regulation").
Article 2. The Requirements apply to all boiler and pressure vessel product
manufacturers which specifies in “Administration Regulation” (hereinafter referred to
as manufacturer).
此文章介绍锅炉、废热锅炉制造许可,以及压力容器制造许可。压力容器制造制造能力需求。
详见原文
http://www.csei.org.cn/IRC/admin ... 080408113747485.pdf
Non-standard Pressure Vessel Market
个人评分
查看全部
Peterpaul彼得保罗
          本站系信息发布平台,仅提供信息内容存储服务,发布人对所发布的内容负责。
          包括但不限于:不能公开传播或无所有权、禁上发布的出版物、涉密内容等
关闭
海川推荐上一条 /3 下一条
关于我们  -  隐私协议    -  网站声明   -  投放广告   -  企业服务包   -  会员VIP  -  管理统计
化海川流  -  海川市场    -  众包悬赏   -  分类信息   -  视频学课   -  在线计算  -  单位换算
客服电话18840911640(微信同号)   0411-88254066-1      找专业人才: 点击这里给我发消息
电子邮箱 service@hcbbs.com     或  站内信 清洁工      找技术服务产品: 点击这里给我发消息
GMT+8, 2022-6-28 02:52   平台统计:
化海川流(hcbbs.com) Copyright By ,0.120329 second(s), 40 queries , Redis On.
辽公网安备21100302203002号  | 辽ICP备17009251号  |  辽B2证-20170197
