海川化工论坛-化海川流
用户名账户登录
用户名密码方式登录
QQ
      输入要查询的主题编号:
热点议题
末端冷却器芯子寿命如此短暂
末端冷却器芯子结构为整体穿管式。
化工企业固定资产折旧问题
在化工企业中,一般的设备、机械等均按年折旧
焦炭塔工况切换的温度
焦化两塔一炉,塔在切换的时候,A塔生焦
开这样的洞,塔体会不会垮掉?
裙座上开这样的门洞有哪些讲究
查看: 1.4K|回复: 2
收起左侧
阑尾并非一无是处 [帖子923785]
累计签到:1936 天
连续签到:1 天
未设置个人头衔
未启用展示信息
我的化工日志
发表于 2011-10-31 11:11:41 | 显示全部楼层 |阅读模式
注册化海川流平台,对接480万工业人圈子
您需要 登录 才可以下载或查看,没有帐号?注册
Everyone is born with one, but no one knows what it's for. The human appendix is a small dead-end tube connected to the cecum, or ascending colon, one section of the large intestine. Everyone lives happily with it until it becomes painfully inflamed, when the only treatment is to remove it surgically.
Then everyone lives happily without it. So why is it there in the first place?
Some experts have guessed that it is a vestige of the evolutionary development of some other organ, but there is little evidence for an appendix in our evolutionary ancestors. Few mammals have any appendix at all, and the appendices of those that do bears little resemblance to the human one.
Last December, researchers published a novel explanation in The Journal of Theoretical Biology. The appendix, they suggest, is a "safe house" for commensal bacteria, the symbiotic germs that aid digestion and help protect against disease-causing germs.
Structurally, the appendix is isolated from the rest of the gut, with an opening smaller than a pencil lead, protected from the fecal stream that might be carrying pathogens. In times of trouble like a diarrheal infection that flushes the system, these commensal bacteria could hide out there, ready to repopulate the gut when the coast is clear.
William Parker, the senior author of the study and an assistant professor of surgery at Duke, emphasized that this was a hypothesis, not experimental proof. "At this point," Dr. Parker said, "this is a deduction based on a lot of information that we've had for many years and some key pieces of information that have only been uncovered recently by our lab and others. It does make sense."But an experiment to prove this theory would be very expensive. And in any case, why would you want to spend money to find out something that is not likely to help cure a disease?"
Rebecca E. Fisher, an assistant professor of anatomy at the University of Arizona College of Medicine, said that although the appendix was "likely to be a derived feature, selected for a purpose, the enigma is that we didn't know what that purpose might be." "I think Parker's study offers an interesting solution," Professor Fisher said.
Recent studies have found that biofilms, colonies of beneficial microbes that live outside cells, form in the large intestine, where they are dependent on the mucus that lines the bowel. There, they aid digestion and protect against infection, while enjoying the protection and nutrition of the human host.
The researchers, examining tissue from uninfected human appendices removed in kidney-pancreas transplants, found biofilms on the epithelial lining of the appendix, as well. Under their theory, it is in these biofilms in the appendix, well positioned to avoid pathogens in the rest of the gut, that commensal bacteria take refuge.
If that is true, why is it that removing the appendix apparently does not have negative side effects? The scientists contend that in industrialized countries with modern medical care and sanitation, maintaining a reserve of helpful bacteria has become unnecessary. Widespread outbreaks of intestinal disease are so rare that the commensal bacteria face little danger of extermination.
Dr. Parker wants to know whether biofilms function in the same way in other animals. "We already have an idea that the cecum in some animals works the same way," he said. "But how, for example, do biofilms work in frogs and other species with no cecum and no appendix?"
Whether the human appendix has the function Dr. Parker thinks it has or whether it has no function at all, it is clear, he said, that "if your appendix gets inflamed, forget about the fact that it might have some function.""You have to get it out," he added. "Appendicitis can be life threatening, and the earlier you treat it, the less likely it is that you will die from it."
我们生下来就带着它,可没有人知道它是做什么用的。人的阑尾是个很小的一端闭锁的细长盲管,它的另一端连结盲肠,也叫升结肠,属于大肠的一部分。平时我们生活得很好,直到它发了炎,产生剧痛。这时,唯一的治疗方法就是动手术把它切除,然后我们又继续快乐地的生活。
那么,人当初为什么会长阑尾?
专家猜测它是人类进化发展中某个退化了的器官,可是几乎没有证据表明进化为人的物种曾长过阑尾,很多哺乳动物干脆就没有阑尾,即便有些有阑尾,它的形状跟人的也几乎没有相似之处。
在2007年12月出版的《理论生物学杂志》上,研究人员给出一个新颖的解释,他们认为,阑尾是肠道共栖菌的“安全屋”,而共栖菌能帮助人消化及抵御致病细菌。
从构造上看,阑尾位于盲肠的末端,不与其他部分连结。它有一个比铅笔心还细的开口,防止了可能携带病原菌的废物流入其中。在人得了腹泻,肠道不适的时候,这些共栖菌就会躲藏在阑尾里面,等待着症状缓解以后,好重新再回到肠道内。
威廉姆·帕克是美国杜克医学院外科助理教授,他还是这个研究成果的第一作者。他强调这只是一种假设,不是实验证明。他说:“目前,这种推论建立在我们多年来所掌握的大量理论的基础之上,其中一些重要理论最近才在我们的实验室和其他实验室里得到证明。这确实很有意义。但是,证明这个理论的实验会非常昂贵。无论如何,谁会愿意花钱探寻一件似乎对治疗疾病没有帮助的事情呢?”
美国亚利桑那大学医学院解剖学助理教授丽贝卡·费雪认为,虽然阑尾“很可能是为某种目的而形成的器官,但问题是我们不知道它是为什么目的而形成的。”她说:“我觉得帕克的研究给出了有趣的解释。”
最近的研究发现,有益菌生活在细胞之外,在大肠内形成生物薄膜,靠肠道内的粘液存活并帮助人体消化和抵御感染,同时它也从人体获取保护和营养。
研究人员从胰肾联合移植者身上取下未被感染的阑尾,并对其组织进行检查发现,阑尾的上皮内壁也有生物薄膜的存在。按照他们的理论,正是这些阑尾中的生物薄膜给共栖菌提供了一个避难所,因为阑尾在人体内的有利位置使共栖菌避免受到其他肠道病原体的侵袭。
如果这一理论正确,那为什么切除阑尾没有对人体产生明显的负面效果?专家们强调说因为工业化国家有先进的医疗条件和卫生设备,所以生活在那里的人阑尾内继续储备有益细菌已经变得无关紧要。而且发达国家大规模爆发肠道疾病的可能性很小,使共栖菌被消灭的危险性也大大降低。
帕克博士想弄清楚生物薄膜在其他动物身上是否也以同样方式在起作用。他说:“我们已经有了这种想法,就是盲肠在一些动物体内起作用的方式与人相同,但是譬如青蛙以及其他一些没有盲肠或阑尾的物种,生物薄膜又是如何起作用的,目前不得而知。”
总而言之,不管人的阑尾是否像帕克博士认为的那样有用还是根本毫无用处,有一点是清楚的,就是像帕克所说的:“如果你的阑尾发炎了,别去想它是否还有用,你必须把它拿掉,”他解释说:“因为阑尾炎会危及生命,越早治疗,死于阑尾炎的可能性就越小。”
        转摘自海词快乐英语,供海友们分享
上一篇:焊工钢印分布图等-如何翻译比较专业
下一篇:dodge ball?
声明:当前内容由会员用户名 gd0308 发布!权益归其所有 仅代表其个人观点,仅供学习交流之用
网友及版主海友依个人意愿的点评互动、推荐等,均不代表本站认可其内容或确认其权益归属, 也不代表本站立场
平台上所有广告、推广、信息等由会员分享,浏览者需自行判断其内容真实性或可用性,并自负因使用相关信息造成的后果
本站系信息发布平台,仅提供信息存储服务,如您对此内容存在争议或认为侵犯您的权益,可联系我站举证删除处理,我站在线客服或致信service@hcbbs.com 188-4091-1640网站声明
累计签到:2 天
连续签到:0 天
未设置个人头衔
未启用展示信息
我的化工日志
发表于 2011-10-31 11:47:00 | 显示全部楼层
看过!中国仪器仪表展览网www.china-1718.com
Peterpaul彼得保罗
声明:当前内容由会员 shinee 发布,仅代表其个人观点不代表本站立场,仅学习交流之用、如有网友或网友版主等依个人意愿参与点评互动或推荐,不代表本站认可其内容或确认其权益归属, 本站系信息发布平台,仅提供信息存储服务,如此内容存在争议或侵犯您的权益,请联系我站在线客服删除处理 188-4091-1640 网站声明
使用道具 举报给管理员
累计签到:1050 天
连续签到:1 天
未设置个人头衔
未启用展示信息
我的化工日志
发表于 2011-11-1 12:06:16 | 显示全部楼层
学习 受用 感恩无私分享!
声明:当前内容由会员 cammy166 发布,仅代表其个人观点不代表本站立场,仅学习交流之用、如有网友或网友版主等依个人意愿参与点评互动或推荐,不代表本站认可其内容或确认其权益归属, 本站系信息发布平台,仅提供信息存储服务,如此内容存在争议或侵犯您的权益,请联系我站在线客服删除处理 188-4091-1640 网站声明
使用道具 举报给管理员
悬赏任务等你参与
          特别提示:本站系信息发布平台,仅提供信息内容存储服务,请勿发布有权属争议内容(不能公开传播或无所有权的出版物、涉密内容)不听劝告后果发布人自负!造成平台或第三方损失的,依法追究相关责任。
最新课程
关闭
平台提醒上一条 /1 下一条
联系我们
关注我们
回到顶部
关于我们     -     隐私协议     -    网站声明     -     广告投放     -     企业会员     -     个人会员 -     管理统计
广告商务: 18840911640周经理(微信同号) 点击这里给我发消息   网站客服: 17615162310王经理(微信同号) 点击这里给我发消息
联系电话 0411-88254066      电子邮箱 service@hcbbs.com
本站法律顾问 : 谢晨曦 主任律师   化海川流HCBBS-海川化工论坛社区-化工交流第一站
GMT+8, 2021-6-21 06:07   社区统计:
化海川流(hcbbs.com) Copyright By ,0.263380 second(s), 88 queries , Redis On.
辽公网安备21100302203002号  | 辽ICP备17009251号
